Yes No
Ads
Tom's Hardware > Forum > Systems > New Build > Help with choosing a MB/CPU combination.
Forum Systems : New Build Help with choosing a MB/CPU combination.
I'm building a budget sytem using an Nvidia GTS 250 that will be used for Folding@home and some gaming.
I'm currently looking at an ASRock G41M-LE, Intel Pentium E6300 Wolfdale 2.8GHz with 2GB DDR2 1066 ram.
I need to keep the MB/CPU/Ram combination around $180 from newegg.com Is this probably the best combination or is there a better one that I'm overlooking. Also I don't intend on overclocking this build.
Thanks,
Jason
Reply to jasond9263
I would have to save you have the best combination for that budget.
Reply to mxknight07
- 0 +
agreed. the amd720 with an asus board, no ram, is selling for a little under $200 on newegg, and that's a great price. So you prolly won't find anything better than a mid level dual core at that price range.
Reply to goony20
you dont need 1066 MHz ram with an C2D chip .
Save yourself some money and buy 800 MHz RAM with lower timings .
Reply to Outlander_04
ASUS P5KPL-CM LGA 775 Intel G31
Cheaper and can OC to 1600 FSB.
Reply to hundredislandsboy
Thanks for all the input.
Reply to jasond9263
There are 2030 identified and unidentified users. To see the list of identified users, Click here.
Ads
Latest best answer
$650 dollar budget 'gaming' rig. Can you help?
By geofelt, 3 hours ago:
To answer your question, an aftermarket cpu cooler is not necessary with a 2100. For $5...
Best offers
Top experts
