Tom's Hardware > Forum > CPU & Components > CPUs > System Speed Difference
Forum CPU & Components : CPUs - System Speed Difference
Will I see much difference between a Q9550, 4 gig ddr800 vs i7 920 2.66 and 6 gig 1600? Its time for an upgrade from my amd 5600 and I'm debating on wether the cost differnce for the i7 upgrades are worth it.
Sponsored Links
Keep your Q and overclock. The Q's better cache helps it out a lot
------------------------------ Core I7 920 D0 @ 4.2Ghz
MSI X58 Pro-E
32GB SSD, WD Blacks In R0
Sapphire HD 5870's In XFire
Reply to PsychoSaysDie
- 0 +
Well it will depending on what your going to be doing with the computer. Like if your going to play games, surf the web, converting files, ect.
If your just the average gamer or user then i would say c2q.
If you a heavy gamer or using professional programs that uses as many threads as possible than i would say i7-920.
Message edited by warmon6 on 09-30-2009 at 08:40:37 PM
Reply to warmon6
I do play games and I'm probably going to get a new 5850 or 4890. Having problems running some games at higher qualites. I wont go xfire or anything but I do like to update stuff every couple years. I mess around with video and audio as well but nothing hard core. Everything else is normal use. I'm not trying to set new benchmark records either but it's time for some new toys. :pt1cable:
Current system
Asus M2ne
amd 5600
4 gig Corsair 800
74 raptor
640 WD Black
ati X1800
creative xgamer
Reply to titaniumasm
- 0 +
then i would say the Q9550. you'll probably wont use the power that the i7 has to offer anytime soon.
or you could go after an i5. It's pretty much an improved core 2 quad. Cheaper than the i7 but as great turbo boost on single thread app's.
Message edited by warmon6 on 09-30-2009 at 09:06:28 PM
Reply to warmon6
My vote is on the Q9550. i7 is awesome for a heavy CF or SLI setup, where bottle-necking comes into factor. But for a single 4890 or 5870 you may only see a few FPS gains in gaming (depends on the game), between the two CPUs. Just my .02.
------------------------------ PII 955 BE CPU @ 3.6ghz w/ TRUE Black HS, 4gb Corsair RAM @ 1600mhz, Antec 1200 case, 650w Corsair PSU, Asus TOP 4890 1gb, Seagate Barracuda 7200.12 500gb HDD / 7200.11 640gb Slave, Windows 7 Pro 64-bit RTM
Reply to brett1042002
There are 702 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
