GTS 250 installation Problem!
Hey guys
Um I have a bit of a problem I was hoping anyone could help me out with
So I've bought a Palit GTS 250 512mb GPU, plugged it all in, powered it up, its all fine and I started installing the new drivers.
Once these drivers have totally installed I am prompted to reboot so I do.
When the computer starts, it runs through everything fine until it gets to the windows screen showing the loading bar.
Then the graphics card's fan slows down and I am flashed with a blue screen very quickly and a message up the top reading "MEMORY_MANAGEMENT"
After this I wiped all VGA drivers from the PC, and reinstalled the new ones but no luck at all
Is this the PSU, I ran tests on the RAM and all is fine
Im running a CODEGEN 450w, with a q6600, 1 optical drive, 2x120mm fans and 1 80mm, and only the single HDD
My previous card was an 8500gt, terrible I know so I need this upgrade.
If its a driver clash is there anyway I can fix this without reformatting windows???
Any Ideas are very appreciated. Thanks
1 answer Last reply
More about installation problem
  1. You only have 16 amps on the 12v rails. You need 26 amps on the 12v rails.
    Requirements:
    475W PCI Express®-compliant system power supply with a combined 12V current rating of 26A or more
    Change that power supply to a Corsair or Seasonic.
Graphics Cards Drivers Graphics
