Need urgent recommendation/help on choosing i7 motherboard.
Hey guys...I really need help on choosing a motherboard for my i7 920 D0 stepping processor (with 6GB 1600 RAM). I'm clueless when it comes to mobos...I am buying a custom built PC on ibuypower.com.
I already chose all the parts and saw all the reviews, but i can't figure out which motherboard to get. I plan to do a lot of overclocking (I'm getting a liquid cpu cooler), so a motherboard that has good overclocking is a must. I heard that the new Asus Premium P6X58D is the best lga1366 motherboard you can get right now for performance:price ratio, but I don't know if I need a high-end motherboard like that. I'm considering:
the Asus P6TD Deluxe,
the MSI X58 Pro-E,
the Gigabyte EX58-UD3R,
the Gigabyte EX58A-UD7,
the Asus P6T SE
I'll appreciate any help...thanks a lot.
1 answer Last reply
More about need urgent recommendation help choosing motherboard
  1. I wouldn't choose either at this point.....Asus P6T Deluxe V2 would be my 3rd choice and closest to the ones you listed..
    2nd http://www.newegg.com/Product/Product.aspx?Item=N82E16813131614
    1st http://www.newegg.com/Product/Product.aspx?Item=N82E16813131390
Motherboards Intel i7
