TTG CODEC problem
Last response: in Home Theatre
February 27, 2005 10:43:46 PM
Archived from groups: alt.video.ptv.tivo (More info?)
I'm having a codec-related problem with Tivo To Go. Here's the situation.
I installed the InterVideo DVD X-Pack, and sure enough, I could load shows
from the TIVO onto the laptop and watch them using Windows Media Player.
The problem is that the 'speed related' control is pause. I can't use the
fast forward or reverse buttons, and I can't even drag the slider to a new
location. In other words, if I want to see a point 1/2 hour into the show,
the only way to do it is to press play and then wait 1/2 hour!
I have heard that this is a codec-related problem, so I downloaded
"DScaler5005.exe". This fixes the problem with navigation, but messes up
the aspect ratio of the film.
Any suggestions as to how I can get both the correct aspect ratio and
navigation?
Thanks.
More about : ttg codec problem
Anonymous
February 27, 2005 10:43:47 PM
What version of Windows Media Player are you using?
Google around for "Windows Media Player" and "incorrect aspect ratio". I
can't recall off hand if it's too new of a version that causes a problem
or too old, but it's one or the other.
You can try a different player, like Zoom Player, or Media Player Classic.
Lenroc
February 27, 2005 10:51:04 PM
"Lenroc" <lenroc@NOSPAMFORYOU.hotmail.com> wrote in message
news:ETtUd.10701$Sn6.9696@lakeread03...
Using version 10.
February 27, 2005 10:54:04 PM
> the fast forward or reverse buttons, and I can't even drag the slider to a
> new location. In other words, if I want to see a point 1/2 hour into the
> show, the only way to do it is to press play and then wait 1/2 hour!
> navigation?
One other issue: Even if I could get the aspect ratio right on the DScaler
codec, I can't really use it, since it causes DVD playing to fail!
In short, I need a codec that will get both navigation and aspect ratio, and
I don't know one that will do both!
Thanks again.
Anonymous
February 28, 2005 4:14:24 AM
This one works for me:
http://www.free-codecs.com/download/Codec_Pack_All_in_1...
The AR is somewhere between 1:1 and 4:3 and the navigation works fine.
"Name" <email@address.com> wrote in message
news:MYtUd.3891$2s.3549@lakeread06...
>> situation. I installed the InterVideo DVD X-Pack, and sure enough, I
>> could load shows from the TIVO onto the laptop and watch them using
>> a new location. In other words, if I want to see a point 1/2 hour into
>> the show, the only way to do it is to press play and then wait 1/2 hour!
>> navigation?
> DScaler codec, I can't really use it, since it causes DVD playing to fail!
> and I don't know one that will do both!
> Thanks again.
February 28, 2005 9:03:25 AM
"BSackamano" <bsackamano@hotmail.com> wrote in message
news:QfuUd.70868$tl3.28068@attbi_s02...
>>> up the aspect ratio of the film.
>>> navigation?
>> fail!
>> Thanks again.
It turns out that resetting the video hardware acceleration to defaults
fixes the navigation problem in WMP. Go figure!
