Hello Everyone!
I have followed Tom's Hardware for quite some time, however I joined only today, Just me being lazy.
I need help overclocking my rig. Yesterday, I bought a new motherboard , an ASrock g41m-vs3 (Extremely similar to this one http://www.newegg.com/Product/Product.aspx?Item=N82E16813157242&cm_re=g41m-_-13-157-242-_-Product) and 2 GB Kingston DDR3 ram @ 1333mhz.
This is my current rig
Q6600 G0 Stepping.
G41m-Vs3 ASrock.
2GB DDR3 ram @ 1333mhz.
Nvidia 8500Gt 1GB ( 720 Mhz coreclock, 482Mhz memory)
WD 500Gb 7200 RPM SATA Drive
Gigabyte casing http://www.gigabyte.com/products/product-page.aspx?pid=2478#sp
Stock coolers, 3 Case fans. Temperatures, 55 at full load for processor, 81 for the GPU and 42 for the motherboard.
I used to have an Intel Dg35ec ( http://www.newegg.com/Product/Product.aspx?Item=N82E16813121336&cm_re=dg35ec-_-13-121-336-_-Product) But had to replace it because USB stopped working on it totally. With that board, I used to overclock the processor till 2960mhz. totally stable with SetFSB . With my new board, Using Asus' Easy OC tuner, (Software used to overclock and control fans from windows) I can't overclock over 2.7Ghz with the multiplier set to 9 and basically just changing the FSB but not the voltage.
Anything higher than 2.7 Ghz gives a BSOD just like anything higher than 2.96 did with my old board.
Thanks a lot. I hope someone can help, I understand I will not be able to overclock much with this aging hardware and stock cooling, but I should atleast be able to reach 2.8-3 Ghz? Thanks again.
Q6600 G0 Stepping.
G41m-Vs3 ASrock.
