Hello!
I had following configuration:
CPU: Procesor AMD Phenom II X4 955 Black Edition, socket AM3, BOX
MBO: Gigabyte MA790XT-UD4P, AMD 790X+SB750, S. AM3, 8xSATA RAID, DDR3
PSU: CORSAIR 550W, VX Series CMPSU-550VXEU, 12cm vent., ATX
MEM: DDR3 4GB (2x2GB) Corsair, 1600MHz, 9-9-9-24, COR-TW3X4G1600C9DHX x2
HDD: HDD WD 1Tb, 1001FALS , SATA II, 32Mb Cache, WD Caviar Black, 72
DVD: Pioneer DVR-117FBK, DVD±RW, 22x crn , ATA
GPU: XFX HD4850 512MB DDR3 625MHz, Dual DVI, HDTV out, HDCP ready
CASE: CoolerMaster Elite 334, black, (W)187 x (H)421 x (L)485 mm, 6kg
It was OK, but too loud. Since I needed to change graphics, and wanted to make my configuration much quieter, I replaced my graphic card with this one:
MSI HD6850 OC Cyclone, 1GB,DVI,HDMI,DX11
The configuration is less noisy, but not nearly as I thought to be - CPU's stock cooler is very loud. Since that noise bothers me rather much, replacing cooler is only solution. However, I need advice on which model to take. My new cooler should be as quiet as possible, and easily installable. I like Scyte Mugen 2 rev. B, because it works good and is rather quiet, but it's installation looks very painful (I wouldn't like to be forced to take MBO out of computer just to be able to install cooler. So, if anyone has any good solution (preferably not too expensive, let's say up to $80) please share...
