Tom's Hardware > Forum > CPU & Components > CPUs > [Solved] How important is the system bus speed?
Forum CPU & Components : CPUs - [Solved] How important is the system bus speed?
Best answer from anort3.
hey!
I'm looking at getting an ASUS K50IN laptop, with Intel Core 2 Duo 2.0 GHz, 2MB cache, and 800MHz system bus speed.
with 4GB RAM DDR2
I'm just wondering if 800 MHz is a bit slow? is it worth paying more for a faster bus?
I mainly want to be able to play Warcraft and watch movies and what not.
Sorry, don't know much about this technical stuff-
Thanks!
Bede wrote :
hey!
with 4GB RAM DDR2
Thanks!
Its standard for the processor in that laptop. Its also not something that you will change in a laptop. In a desktop that number can be raised to overclock or run the processor at a faster than stock speed.
If you are going to spend more in my opinion I would make sure you have a discreet graphics card and not onboard. For what you are doing with it the Core2 with 4 gigs of RAM should be fine but even WOW will benefit from seperate GFX.
Sponsored Links
------------------------------ AMD P2955X4 ATI 5870 DX11 [:boudy:2]
24" dell 1900x1200 2x74 wraptor hd's1 X-FI pro gamer sounds
2G ram log.Z5500 speakers 650w toughpower G15kb dvd....ITS A MEAN GREEN GAMING MACHINE
Reply to sirkillalot
Best answer
Bede wrote :
hey!
with 4GB RAM DDR2
Thanks!
------------------------------ EP-45 UD3R/ E8400@3.6 wZerotherm Nirvana/4gb Corsair DDR2-800/EVGA 9800GTX+/Corsair 750TX/2xWD Black AALS 640gb RAID 0+1 Windows 7/2xWD Cavier 250gb RAID 0 Windows XP Pro/Seagate 160gb Backup/X-Fi Xtreme Gamer/Logitech Z-2300/Samsung SynchMaster 906BW
Reply to anort3
There are 1307 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
