Hi,
I just finished building a PC, which uses this card.
I know that the card uses the RALINK RT2500 chipset. I downloaded and installed the Ralink RT2500 drivers, and manually setup the card using the Windows 7 Device Manager.
The card was working perfectly until I decided to remove it from its PCI slot, and the booted up the PC.
Windows 7 still detects the card, but tells me that there was an error in installing the drivers.
I uninstalled and re-installed the RALINK drivers. This has not solved the problem.
Can someone please give me some advice here.
Thanks.
Thanks.
