I have 1 System HDD and 2 HDD in mirror set , will it work ?
  • Hard Drives
  • SATA
  • Hewlett Packard
  • Mirror
  • Storage
Last response: in Storage
March 22, 2011 12:08:16 PM
Hello, I am using HP 7400 machine with 250 GB HDD ,2008 Stnd edition installed and HDD connected to Sata port 0 of motherboard. now i have got 2 1TB Hdds and 1 Adaptec raid controler ( 2 SATA port )
i have created mirror set with 2 1TB HDDs , it installed properly , now after restart the machine my 2008 is not booting.
please help if this scenario works
More about : system hdd hdd mirror set work
March 22, 2011 12:24:52 PM
let me clear more:- i have 250 GB hdd with no RAID in it and it is my system HDD on which i have my OS installed already. ( this has only one drive C: and that has got total hard disk size of 250).
now i got 1 RAID adaptec 1220SA controler which having 2 SATA ports, i have installed that RAID card to my PCIex , and installed 2 1TB hdds to it and created RAID 1 Array ( Mirror) it completed succesfully . but after this all i am unable to boot from my system HDD ( 250 GB ). and when i remove HDD from my RAID and try to boot , it boots up :)  . so where is issue ?
so question is does RAID work if system HDD is not part of RAID ?
m
l
a c 386 G Storage
March 22, 2011 1:07:07 PM
Check your bios for the correct boot order and boot drive.
m
l
March 22, 2011 2:55:07 PM
HI, thanks for reply. BIOS settings are corrrect. default boot HDD is local HDD of System( 250 GB).
m
l
a c 386 G Storage
March 22, 2011 4:34:39 PM
That's odd. If your RAID controller has a boot option in it's bios, make sure it is disabled. Other than that, not sure what would cause that.
m
l
