HOW MANY VOLT POWER ADAPTER DOES A WD 1 5TB HARDDRIVE USE
I need to know how many volt power adapter does a WD 1.5TB 64MB CACHE USE. MODEL WD15EARS.
5 answers Last reply
More about volt power adapter harddrive
  1. Has one SATA power connector. Uses the +5V and +12V. And probably < 10 watts when writing Standby power probably <2 watts (for manuf specs on wattage go to WD site, normally not a concern when used inside a computer. If installing in a external enclouser, then use a power adaptor.
    It can use 3.3V, 5.0V and 12V, but it will work with 5 and 12V only - During read/write it consume about 6W of power
  3. AFAIK, WD uses 12V 3A switchmode AC adapters for their MyBook externals.
    According to the following document, the WD15EARS has a peak current demand of 1.55A on the 12V supply. The average total power requirement for both the +5V and +12V supplies during Read/write is 4.5W.
    WD Caviar Green Series Disti Spec Sheet:
    http://www.wdc.com/wdproducts/library/SpecSheet/ENG/2879-701229.pdf
  4. ZO MAH GOD!!! theres 5TB hard drives now!?
  5. do 900000000 wats
Hard Drives Western Digital Power Adapter Storage
