^ Hi not mock you or anything but this build would have been a very good one a year back...I guess you have been out of the circle for long...
Newer CPUs are out from intel and AMD after the Q6600, which perform better than the Q6600 for less...
If you are intel specific, then you should look at the Q8400...If you are OK with AMD, then the P II X4 940...
+1 for the Sunbeam h/s. Also it comes with great thermal compound. This cpu and mobo combo down below is a great deal, not to mention that q9550 is an over clocking beast !
^+1
And thought the Q8400 has less cache, it is a 45NM CPU compared to the 65NM Q6600 and it has better efficieny than the Q6600...It performance would be very similar or better than the Q6600...
And @Thorox I dint notice that the Q9550 with that gigabyte combo would come to [price of Q6600 + P5Q...Else I would have certainly recommended that...
^+1
That Mobo looks promising, maybe ill go with q9550 with your recommended GIGABYTE GA-EP45-UD3P only $ 9 more dollars than the q6600 on New egg but you kno those few dollars here few dollars there add up
Thx for the newegg links ha ha but I was hoping to spend around $900 for the whole system the mobo you and gkay09 mentioned is the same price as the asus p5qe. hmm... maybe ill just save my money, no use trying to be a cheapo and regret buying.
Hey would the http://www.newegg.com/Product/Prod [...] 6813128358
be able to cross fire in the future even tho one pci-e slot is x16 and the other is x8
Hey would the http://www.newegg.com/Product/Prod [...] 6813128358 be able to cross fire in the future even tho one pci-e slot is x16 and the other is x8
links broke, but yep, all those p45 boards are x16 and x8 as far as i know and they xfire just fine.
mmk I appreciate your help anything else you think I could change? just seen a vid that says if you had xfire the pci would be x8 instead of x16 is that bad?
nope. they did benchmarks on that and there was little diff. if any in most all of them. your good to go with that board in xfire.
^Have seen many people using WIN 7 as their Primary OS...So better check out the WIN forums for your concerns...
And I suggest you change the RAM to this...
intel CPUs dont take advantage of speeds above 800MHz...So better off buying DDR2 800 with lower CAS - 4...
OCZ Reaper HPC Edition 4GB (2 x 2GB)
http://www.newegg.com/Product/Prod [...] 6820227267
