Tom's Hardware > Forum > Homebuilt Systems > New System Build > Help me decide which I should go with Q9550 or i7 920 build. Final ver
Forum Homebuilt Systems : New System Build - Help me decide which I should go with Q9550 or i7 920 build. Final ver
Hi these are my final versions and I am just about to buy.
This machine is going to be used as a virtual pc host and will have WIN2K8 installed on it. Pref using Hyper V for VMCs. It will not be a gaming machine so it doesnt need any hot GPU wise.
All it needs is a decent multicore CPU and RAM.
Here are the specs I have put together. Please check to see if the parts look compatible or what could I swap out to make it cheaper.
And which one would you go for?
Intel Q9550 Build
CPU: Intel Core 2 Quad Q9550, Yorkfield Core, S775, 2.83GHz, 1333MHz, 12MB L2 Cache, 8.5x, 95W, Retail £169.96
CASE: Antec Three Hundred Black Midi Tower Case w/o PSU £45.97
MOBO: Asus P5Q PRO, iP45, S 775, PCI-E 2.0 (x16), DDR2 1200MHz, SATA II, SATA RAID, ATX £99.46
HDD: 1TB Samsung HD103UJ Spinpoint F1, SATA 3Gb/s, 7200rpm, 32MB Cache, 8.9 ms, NCQ £63.81
RAM: 4GB (2x2GB) Corsair TwinX DDR2 XMS2, PC2-8500 (1066), 240Pin, Non-ECC Unbuffered, CAS 5-5-5-15, EPP £93.47
GPU: 512MB Sapphire HD 4350, PCI-E 2.0(x16), 800MHz GDDR2, GPU 600MHz, 80 Cores, D-Sub/ HDTV/ DL DVI-I £28.34
DVD: LG GH22NS40 22x DVD±R, 16xDVD±DL, DVD+RW x8/-RWx6 ,12xRAM SATA, Black, OEM £16.43
PSU: 700W Storm LPK19-35 ,120mm Silent Fan, 24pin +4 pin +12V PSU ATX 2.2 £26.39
Total £557.15
Intel i7 920 Build
CPU: Intel i7 920, S 1366(B), Nehalem, 2.66GHz, QPI 4.8GT/s, Cache 8MB, 20x Ratio, 130W, Retail, (SLBEJ) £211.80
MOBO: Asus P6T SE, Intel X58, Sok 1366, PCI-E 2.0 (x16), DDR3 2000/1866/1800, SATA 3Gb/s, SATA RAID, ATX £141.65
RAM: 6GB (3x2GB) Corsair XMS3 DDR3, PC3-12800 (1600MHz), 240 Pin, Non-ECC Unbuffered, CAS 9-9-9-24 £78.03
Total £625.35
Sponsored Links
any helpers?
Thanks
Reply to midi25
- 0 +
Depends on budget. With only a 75 pound difference, I'd stretch to an i7.
You do need to budget for a better power supply, though.
Reply to jsc
- 0 +
+1 for the i7 and better PSU...
Rather spend little more on better PSU now than taking the risk of powering those costly components with a cheap, low quality PSU...
Even the Antec EA500/ Corsair 450VX PSU is more than suffice for that setup...and they are 80+ certified and far better than some unknown brand 700W PSU...
Reply to gkay09
- 0 +
True.
But i,m trying to save some £££ on the build.
I have a Corsair 700W in my other i7 920 PC.
What decent PSU can I put in the i7 build then without too much additional cost?
Thanks
Reply to midi25
- 0 +
[url=http://www.scan.co.uk/Products/500W-Silverstone-ST50F-Silent-PSU-120mm-Fan-Dual-plus12V]
[/url]Thanks I may go for this one then.
Reply to midi25
- 0 +
*** N *** N *** N *** N WORLD OMFG...............
Reply to zhemin
- 0 +
Just ordered the following spec
550w Corsair VX Series PSU, ATX, PS/2, 5 year Warranty
512MB Gigabyte HD 4350, PCI-E 2.0(x16), 800MHz GDDR2, GPU 650MHz, 80 Cores, D-Sub/ DL DVI-I/ HDMI
Total £665.40
Reply to midi25
There are 528 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
  • 01:00 vianescute won the Freshman badge
  • 01:00 meywd won the Freshman badge
  • 01:00 nayega won the Freshman badge
  • 01:00 gpfear won the Freshman badge
  • 01:00 Conrad925 won the Freshman badge
  • 01:00 skythra won the Freshman badge
  • 01:00 Ckaz won the Freshman badge
  • 01:00 james59 won the Uniformed badge
  • 01:00 snarl won the Uniformed badge
  • 01:00 patlabor44 won the Uniformed badge
