Tom's Hardware > Forum > Homebuilt Systems > General Homebuilt > How bigger power supply do I need?
Forum Homebuilt Systems : General Homebuilt - How bigger power supply do I need?
Hi,
I have a Gigabyte P5Q3 mobo with a Geforce 4850 display card (with 2 power leads to it. 2.8 CPU Intel, running 2 LCD monitors. 4 GB Ram.
Inside XP box I have
2 x Seagate SATA 500 GB
1 x WD SATA 500GB
1 x WD SATA 640 GB
1 x LG CDrom SATA
4 external USB GDs each with their own power supply thru a hub with it's owm power supply.
My box Power supply is.. 650W (P4-C650)
A/C input 115/220 (using 240 Australia) 50-60Hz 6a/4a
DC out +3.3v | +5 | +12 V1 | +12V2 | -12V | +5VsB
Max a
32a | 48a | 20A | 18 A | 08 | 3.5 A Total Max 650.
Do I have enough power please in my power supply, and is there anything I should be aware of here?
Thanks,
oz
Sponsored Links
You have plenty of power for your listed configuration.
Reply to jsc
No problem with your 650.
Reply to cmichael138
yeah, you could probably put another 4850 in there with that much power.
Reply to thefox14
just a quick bit of advice, have a look on the power supply's label and see if it lists the total available watts on the 12V rails thats the number you want to look at
from what ive read that PSU is a cheap generic rebranded shaw psu and probly wont be able to deliver anywhere close to 650 watts on the 12v rails
just going by the label itself and using a calculater the 3.3 and 5v rails add up to 345 watts leaving 305 for the 12v rail and thats only if it can deliver the full 650 watts.
granted all this info is based on my own research but im pretty sure its accurate if i am wrong im sure somebody will correct me
but just be careful about adding to much to your system generic psus can sometimes burn out easily and can take your comp with them
skimp out on a vid card skimp out on a processor hell even skimp out on a keyboard and mouse but never skimp out on a power supply
oh and to answer the question even though its a bit old, a good quality 350-500 watt will handle that set up
Message edited by Nayanak on 08-18-2009 at 04:06:49 AM
Reply to Nayanak
no probs, a quality 550 could take that
Reply to ahem
lol a quality 400w could take it ;)
------------------------------ http://www.speedtest.net/result/638783794.png
Reply to stevensl2
There are 617 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
