Monitor wont work
Forum Homebuilt Systems : General Homebuilt - Monitor wont work
New build:
ASRock A790GXH/128M AM2+ ATX Phenom II ready
Asus Radeon HD 4890 1GB GDDR5
Corsair 650W
Samsung 22" Wide Syncmaster T220
AMD Phenomâ„¢ II X3 720 Black Edition
Corsair Dominator TWIN2X PC8500 4GB DDR2
Unfortunately it doesn't work.
Well, everything seems to run fine but my monitor wont come out of standby.
What could be the problem?
Both 8pin and 24pin is connected to the motherboard. I have tried to connect the monitor to both the onboard GPU and the ATI 4890 GPU with wvery cable possible.. but with no result..
Any ideas??
Thanks
/David
Sponsored Links
So everything powers up but no video? I would try reseting the CMOS, if that doesn't work it's probobly the CPU.
Reply to bpjb81
This checklist should help you narrow the problem down:
http://www.tomshardware.co.uk/foru [...] _13_0.html
Reply to shortstuff_mt
Ok
I have gone through the checklist and everything seems to be installed correctly.
However, It still aint working.
I get the following series of beep codes;
1 short beep then a long break
then 1 beep and two seconds after another 2 beeps.
then a little break on a few seconds
then another beep.
I simply don't get it. :(
Reply to Anonymous
Tom's Hardware > Forum > Homebuilt Systems > General Homebuilt > Monitor wont work
There are 847 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
