Hey all!
Im no newbie when it comes to computers, but im lacking ONE SATA molex connector for a hard drive, right now im running a 4pin molex converter. Would it be a *bad* idea to cut the wires to the standard 4 pin molex, and run another SATA one? (of course i would have to tap into the connector for the last wire, on the previous SATA molex though)
Just curious what you guys think. Btw, its a 420W ENERMAX P/S, so its not a cheap one.
I was going to, but i have the spare molex here, and i dont mind actually soldering and heatshrinking it. ANd it will look alot cleaner IMO. My case as it is, is full of cables...
To be honest, that's what I would do. But then, I have more than 40 years of experience maintaining all sorts of military electronics, so my soldering skills are more than adequate.
Good enough for me. Now i guess i should ask though, will i experience a voltage drain on that line cause of the extra molex? Already, i think my PS may be too small for the stuff im running. I'll shoot a list off so at least you can give a comment on it:
Pheneom 2 X550 (NOT OVERCLOCKED)
Asus M4A78 PLUS
ATI Radeon 4670 (saphire, motherboard run)
4 GB's of DDR800 ram (generic)
2x 500Gb hard drives
1x 1TB hard drive (all SATA)
1X DVD SATA drive
1X DVD IDE drive (for on the fly copying)
Onboard sound (Digital optical out)
All this is running on a 420W Enermax P/S. I have a feeling i may be running short on power.
The problem with this, is that the part i need is for a SATA drive. Im just going to cut and splice into my SATA power connector, and run the new wire there. I'll post a pic when im done, about what exactly im doing (Although, i think JSC knows what im doing)
Can you buy a cheap Watt meter e.g. from a local hardware store?
Don't forget to power your monitor and other peripherals via a separate circuit, so you can isolate the Wattage demand by that PSU.
Without having any specific details about the power requirements of each of your components, I am going to venture a guess that they are pulling about 300 Watts MAXIMUM i.e. well within the Wattage rating of that PSU.
MRFS
Message edited by MRFS on 10-03-2009 at 06:48:29 PM
To answer that question with confidence, you would need to know the AMP rating of the PSU's rail that powers that cable.
There is a major difference between PSUs with only one rail, and PSUs that use multiple rails: the rated Wattage will NOT reflect the maximum current rating of any given rail in a multi-rail PSU.
There should be a UL plate somewhere on your PSU, with details about maximum AMPs for each rail.
WHEN IN DOUBT, try to "spread" the load across all available peripheral power cables e.g. either 4-pin Molex or SATA input DC.
Assume about 10-12 Watts PER HDD, maybe 15 during spin-up.
The other power cables are easily identified, and they do NOT connect to disks and optical drives e.g. 4- or 8-pin motherboard power, and PCI-E video card(s) supplemental power.
AMPs for each rail.
MRFS
Wow man, your just full of information. It looks like, according to my PSU info, i should have enough power for all 3 drives on one line. What im going to do, is remove one regular MOLEX, and put a SATA one on there. Heatshrink and solder as well of course.
Thanks for the help man. Muchly appreciated. I'll take some shots of my PC after its done. I gotta clean up a couple wires first
