Closed
Geforce fx 5500 problem
July 25, 2009 1:25:12 PM
Can you help me? I have Nvidia Geforce fx 5500.When i run FSX it's said
"Invalid Hardware or Driver Detected
Flight Simulator is not working with video card
Verify that you have the latest drivers installed for your video card"
I have the latest driver install.It's the 175.19.
When I run dxdiag and I click the display tab it's said"Approx. total memory=N/A
DirectDraw acceleration:Not available
Direct3D acceleration:Not available
AGP Texture acceleration:Not available
Thank you for your help.
Here is dxdiag information:
System Information
Time of this report: 7/17/2009, 17:16:15
Machine name: NZN-C1AC9136E34
Operating System: Windows XP Professional (5.1, Build 2600) Service Pack 3 (2600.xpsp.080413-2111)
Language: English (Regional Setting: English)
System Manufacturer: Acer
System Model: ASPIRE T300
BIOS: )Phoenix - Award WorkstationBIOS v6.00PG
Processor: Intel(R) Pentium(R) 4 CPU 1.80GHz
Memory: 512MB RAM
Page File: 431MB used, 818MB available
Windows Dir: C:\WINDOWS
DirectX Version: DirectX 9.0c (4.09.0000.0904)
DX Setup Parameters: Not found
DxDiag Version: 5.03.2600.5512 32bit Unicode
DxDiag Notes
DirectX Files Tab: No problems found.
Display Tab 1: No problems found. Direct3D functionality not available. You should verify that the driver is a final version from the hardware manufacturer.
Sound Tab 1: No problems found.
Music Tab: No problems found.
Input Tab: No problems found.
Network Tab: No problems found.
DirectX Debug Levels
Direct3D: 0/4 (n/a)
DirectDraw: 0/4 (retail)
DirectInput: 0/5 (n/a)
DirectMusic: 0/5 (n/a)
DirectPlay: 0/9 (retail)
DirectSound: 0/5 (retail)
DirectShow: 0/6 (retail)
Display Devices
Card name: NVIDIA GeForce FX 5500
Manufacturer: NVIDIA
Chip type: GeForce FX 5500
DAC type: Integrated RAMDAC
Device Key: Enum\PCI\VEN_10DE&DEV_0326&SUBSYS_00000000&REV_A1
Display Memory: n/a
Current Mode: 1024 x 768 (32 bit) (72Hz)
Monitor: Plug and Play Monitor
Monitor Max Res: 1600,1200
Driver Name: nv4_disp.dll
Driver Version: 6.14.0011.7519 (English)
DDI Version: unknown
Driver Attributes: Final Retail
Driver Date/Size: 5/16/2008 14:01:00, 6108928 bytes
WHQL Logo'd: Yes
WHQL Date Stamp: n/a
VDD: n/a
Mini VDD: nv4_mini.sys
Mini VDD Date: 5/16/2008 14:01:00, 6557408 bytes
Device Identifier: {D7B71E3E-4066-11CF-EF7E-0B2000C2CB35}
Vendor ID: 0x10DE
Device ID: 0x0326
SubSys ID: 0x00000000
Revision ID: 0x00A1
Revision ID: 0x00A1
Video Accel:
Deinterlace Caps: n/a
Registry: OK
DDraw Status: Not Available
D3D Status: Not Available
AGP Status: Not Available
DDraw Test Result: Not run
D3D7 Test Result: Not run
D3D8 Test Result: Not run
D3D9 Test Result: Not run
Sound Devices
Description: Yamaha DS1x Native Audio
Default Sound Playback: Yes
Default Voice Playback: Yes
Hardware ID: PCI\VEN_1073&DEV_0012&SUBSYS_00121073&REV_00
Manufacturer ID: 1
Product ID: 100
Type: WDM
Driver Name: ds1wdm.sys
Driver Version: 5.01.2501.0000 (English)
WHQL Logo'd: Yes
Date and Size: 8/17/2001 12:20:18, 334208 bytes
Other Files:
Driver Provider: Microsoft
HW Accel Level: Full
Cap Flags: 0xF5F
Min/Max Sample Rate: 5000, 48000
Static/Strm HW Mix Bufs: 4, 3
Static/Strm HW 3D Bufs: 0, 0
HW Memory: 0
Voice Management: No
EAX(tm) 2.0 Listen/Src: No, No
I3DL2(tm) Listen/Src: No, No
Sensaura(tm) ZoomFX(tm): No
Registry: OK
Sound Test Result: Not run
Sound Capture Devices
Default Sound Capture: Yes
Default Voice Capture: Yes
Cap Flags: 0x41
Format Flags: 0xFFF
DirectMusic
DLS Path: C:\WINDOWS\SYSTEM32\drivers\GM.DLS
DLS Version: 1.00.0016.0002
Acceleration: Enabled
Ports: Yamaha DMusic, Hardware (Kernel Mode), Output, DLS, Internal, Default Port
MPU-401, Hardware (Kernel Mode), Input, No DLS, External
MPU-401, Hardware (Kernel Mode), Output, No DLS, External
Yamaha PCI External MIDI, Hardware (Kernel Mode), Input, No DLS, External
Yamaha PCI External MIDI, Hardware (Kernel Mode), Output, No DLS, External
Yamaha DS1x Native Audio, Software (Kernel Mode), Output, DLS, Internal
Microsoft MIDI Mapper [Emulated], Hardware (Not Kernel Mode), Output, No DLS, Internal
Microsoft GS Wavetable SW Synth [Emulated], Hardware (Not Kernel Mode), Output, No DLS, Internal
MPU-401 [Emulated], Hardware (Not Kernel Mode), Output, No DLS, External
Yamaha PCI FM Synthesizer [Emulated], Hardware (Not Kernel Mode), Output, No DLS, Internal
Yamaha PCI External MIDI [Emulated], Hardware (Not Kernel Mode), Output, No DLS, External
MPU-401 [Emulated], Hardware (Not Kernel Mode), Input, No DLS, External
Yamaha PCI External MIDI [Emulated], Hardware (Not Kernel Mode), Input, No DLS, External
Microsoft Synthesizer, Software (Not Kernel Mode), Output, DLS, Internal
Registry: OK
DirectInput Devices
Device Name: Mouse
Attached: 1
Controller ID: n/a
Vendor/Product ID: n/a
FF Driver: n/a
Device Name: Keyboard
Attached: 1
Controller ID: n/a
FF Driver: n/a
Poll w/ Interrupt: No
Registry: OK
USB Devices
+ USB Root Hub
| Vendor/Product ID: 0x1039, 0x7001
| Matching Device ID: usb\root_hub
| Service: usbhub
| Driver: usbhub.sys, 4/14/2008 12:00:00, 59520 bytes
| Driver: usbd.sys, 4/14/2008 12:00:00, 4736 bytes
Gameport Devices
+ PCI bus
| Matching Device ID: *pnp0a03
| Service: pci
| Driver: pci.sys, 4/14/2008 12:00:00, 68224 bytes
+-+ Standard Game Port
| | Matching Device ID: *pnpb02f
| | Service: gameenum
| | Driver: gameenum.sys, 4/14/2008 12:00:00, 10624 bytes
+ YAMAHA Native DS1 WDM Driver
| Matching Device ID: pci\ven_1073&dev_0012&subsys_00121073
| Service: ds1
+-+ Game port for Yamaha DS1
| | Matching Device ID: *ymh0101
| | Service: gameenum
PS/2 Devices
+ Standard 101/102-Key or Microsoft Natural PS/2 Keyboard
| Matching Device ID: *pnp0303
| Service: i8042prt
| Driver: i8042prt.sys, 4/14/2008 12:00:00, 52480 bytes
| Driver: kbdclass.sys, 4/14/2008 12:00:00, 24576 bytes
+ Terminal Server Keyboard Driver
| Matching Device ID: root\rdp_kbd
| Upper Filters: kbdclass
| Service: TermDD
| Driver: termdd.sys, 4/14/2008 07:13:20, 40840 bytes
+ PS/2 Compatible Mouse
| Matching Device ID: *pnp0f13
| Service: i8042prt
| Driver: mouclass.sys, 4/14/2008 12:00:00, 23040 bytes
+ Terminal Server Mouse Driver
| Matching Device ID: root\rdp_mou
| Upper Filters: mouclass
| Service: TermDD
DirectPlay Service Providers
DirectPlay8 Modem Service Provider - Registry: OK, File: dpnet.dll (5.03.2600.5512)
DirectPlay8 Serial Service Provider - Registry: OK, File: dpnet.dll (5.03.2600.5512)
DirectPlay8 IPX Service Provider - Registry: OK, File: dpnet.dll (5.03.2600.5512)
DirectPlay8 TCP/IP Service Provider - Registry: OK, File: dpnet.dll (5.03.2600.5512)
Internet TCP/IP Connection For DirectPlay - Registry: OK, File: dpwsockx.dll (5.03.2600.5512)
IPX Connection For DirectPlay - Registry: OK, File: dpwsockx.dll (5.03.2600.5512)
Modem Connection For DirectPlay - Registry: OK, File: dpmodemx.dll (5.03.2600.5512)
Serial Connection For DirectPlay - Registry: OK, File: dpmodemx.dll (5.03.2600.5512)
DirectPlay Voice Wizard Tests: Full Duplex: Passed, Half Duplex: Passed, Mic: Passed
DirectPlay Test Result: Not run
Registry: OK
DirectPlay Adapters
DirectPlay8 Serial Service Provider: COM1
DirectPlay8 IPX Service Provider: IPX Adapter 1 - (00000000,000AE68239D7)
DirectPlay8 TCP/IP Service Provider: Local Area Connection - IPv4 -
DirectPlay Voice Codecs
Voxware VR12 1.4kbit/s
Voxware SC06 6.4kbit/s
Voxware SC03 3.2kbit/s
MS-PCM 64 kbit/s
MS-ADPCM 32.8 kbit/s
Microsoft GSM 6.10 13 kbit/s
TrueSpeech(TM) 8.6 kbit/s
DirectPlay Lobbyable Apps
Disk & DVD/CD-ROM Drives
Drive: C:
Free Space: 1.2 GB
Total Space: 25.0 GB
File System: FAT32
Model: ST3160812A
Drive: D:
Free Space: 1.5 GB
Total Space: 30.0 GB
File System: FAT32
Model: ST3160812A
Drive: E:
Free Space: 7.5 GB
Total Space: 76.1 GB
File System: NTFS
Model: ST3160812A
Drive: F:
Free Space: 0.7 GB
Total Space: 21.5 GB
File System: FAT32
Model: ST3160812A
Drive: G:
Model: HL-DT-ST CD-RW GCE-8240B
Driver: c:\windows\system32\drivers\cdrom.sys, 5.01.2600.5512 (English), 4/14/2008 12:00:00, 62976 bytes
Drive: H:
Model: ASUS DRW-2014S1
Drive: K:
Model: GK4718S DWZ745Y SCSI CdRom Device
System Devices
Name: Realtek RTL8139/810x Family Fast Ethernet NIC
Device ID: PCI\VEN_10EC&DEV_8139&SUBSYS_813910EC&REV_10\3&61AAA01&0&68
Driver: C:\WINDOWS\system32\DRIVERS\Rtnicxp.sys, 5.707.1030.2008 (English), 10/30/2008 14:10:48, 117120 bytes
Driver: C:\WINDOWS\system32\RtNicProp32.dll, 1.01.0716.2008 (English), 7/16/2008 22:35:28, 9728 bytes
Name: NVIDIA GeForce FX 5500
Device ID: PCI\VEN_10DE&DEV_0326&SUBSYS_00000000&REV_A1\4&3525EC23&0&0008
Driver: C:\WINDOWS\system32\DRIVERS\nv4_mini.sys, 6.14.0011.7519 (English), 5/16/2008 14:01:00, 6557408 bytes
Driver: C:\WINDOWS\system32\nv4_disp.dll, 6.14.0011.7519 (English), 5/16/2008 14:01:00, 6108928 bytes
Driver: C:\WINDOWS\system32\nvsvc32.exe, 6.14.0011.7519 (English), 5/16/2008 14:01:00, 159812 bytes
Driver: C:\WINDOWS\system32\nvapi.dll, 6.14.0011.7519 (English), 5/16/2008 14:01:00, 425984 bytes
Driver: C:\WINDOWS\system32\nvcuda.dll, 6.14.0011.7519 (English), 5/16/2008 14:01:00, 1241088 bytes
Driver: C:\WINDOWS\system32\nvoglnt.dll, 6.14.0011.7519 (English), 5/16/2008 14:01:00, 8769536 bytes
Driver: C:\WINDOWS\system32\nvcpl.dll, 6.14.0011.7519 (English), 5/16/2008 14:01:00, 13529088 bytes
Driver: C:\WINDOWS\system32\nvmctray.dll, 6.14.0011.7519 (English), 5/16/2008 14:01:00, 86016 bytes
Driver: C:\WINDOWS\system32\nvwddi.dll, 6.14.0011.7519 (English), 5/16/2008 14:01:00, 81920 bytes
Driver: C:\WINDOWS\system32\nvnt4cpl.dll, 6.14.0010.11175 (English), 5/16/2008 14:01:00, 286720 bytes
Driver: C:\WINDOWS\system32\nvmccs.dll, 6.14.0011.7519 (English), 5/16/2008 14:01:00, 229376 bytes
Driver: C:\WINDOWS\system32\nvdisps.dll, 6.14.0011.7519 (English), 5/16/2008 14:01:00, 6582272 bytes
Driver: C:\WINDOWS\system32\nvgames.dll, 6.14.0011.7519 (English), 5/16/2008 14:01:00, 3391488 bytes
Driver: C:\WINDOWS\system32\nvmccss.dll, 6.14.0011.7519 (English), 5/16/2008 14:01:00, 188416 bytes
Driver: C:\WINDOWS\system32\nvmobls.dll, 6.14.0011.7519 (English), 5/16/2008 14:01:00, 1257472 bytes
Driver: C:\WINDOWS\system32\nvvitvs.dll, 6.14.0011.7519 (English), 5/16/2008 14:01:00, 3776512 bytes
Driver: C:\WINDOWS\system32\nvwss.dll, 6.14.0011.7519 (English), 5/16/2008 14:01:00, 2629632 bytes
Driver: C:\WINDOWS\help\nvcpl.hlp, 5/16/2008 14:01:00, 177897 bytes
Driver: C:\WINDOWS\help\nvwcplen.hlp, 5/16/2008 14:01:00, 55444 bytes
Driver: C:\WINDOWS\system32\nvcod.dll, 1.03.0000.0017 (English), 5/16/2008 14:01:00, 114688 bytes
Driver: C:\WINDOWS\system32\nvcodins.dll, 1.03.0000.0017 (English), 5/16/2008 14:01:00, 114688 bytes
Name: YAMAHA Native DS1 WDM Driver
Device ID: PCI\VEN_1073&DEV_0012&SUBSYS_00121073&REV_00\3&61AAA01&0&58
Driver: n/a
Name: Multimedia Audio Controller
Device ID: PCI\VEN_1039&DEV_7012&SUBSYS_0A441019&REV_A0\3&61AAA01&0&17
Driver: n/a
Name: SiS PCI to USB Enhanced Host Controller
Device ID: PCI\VEN_1039&DEV_7002&SUBSYS_0A441019&REV_00\3&61AAA01&0&1B
Driver: C:\WINDOWS\system32\drivers\usbehci.sys, 5.01.2600.5512 (English), 4/14/2008 12:00:00, 30208 bytes
Driver: C:\WINDOWS\system32\drivers\usbport.sys, 5.01.2600.5512 (English), 4/14/2008 12:00:00, 143872 bytes
Driver: C:\WINDOWS\system32\usbui.dll, 5.01.2600.5512 (English), 4/14/2008 12:00:00, 74240 bytes
Driver: C:\WINDOWS\system32\drivers\usbhub.sys, 5.01.2600.5512 (English), 4/14/2008 12:00:00, 59520 bytes
Driver: C:\WINDOWS\system32\hccoin.dll, 5.01.2600.5512 (English), 4/14/2008 12:00:00, 7168 bytes
Name: SiS 7001 PCI to USB Open Host Controller
Device ID: PCI\VEN_1039&DEV_7001&SUBSYS_0A441019&REV_0F\3&61AAA01&0&19
Driver: C:\WINDOWS\system32\drivers\usbohci.sys, 5.01.2600.5512 (English), 4/14/2008 12:00:00, 17152 bytes
Device ID: PCI\VEN_1039&DEV_7001&SUBSYS_0A441019&REV_0F\3&61AAA01&0&18
Name: SiS PCI IDE Controller
Device ID: PCI\VEN_1039&DEV_5513&SUBSYS_0A441019&REV_00\3&61AAA01&0&15
Driver: C:\WINDOWS\system32\DRIVERS\pciidex.sys, 5.01.2600.5512 (English), 4/14/2008 12:00:00, 24960 bytes
Driver: C:\WINDOWS\system32\DRIVERS\atapi.sys, 5.01.2600.5512 (English), 4/14/2008 12:00:00, 96512 bytes
Driver: C:\WINDOWS\system32\DRIVERS\pciide.sys, 5.01.2600.0000 (English), 4/14/2008 12:00:00, 3328 bytes
Name: PCI standard host CPU bridge
Device ID: PCI\VEN_1039&DEV_0651&SUBSYS_00000000&REV_02\3&61AAA01&0&00
Driver: n/a
Name: SIS PCI to ISA bridge
Device ID: PCI\VEN_1039&DEV_0008&SUBSYS_00000000&REV_25\3&61AAA01&0&10
Driver: C:\WINDOWS\system32\DRIVERS\isapnp.sys, 5.01.2600.5512 (English), 4/14/2008 12:00:00, 37248 bytes
Name: SIS Processor to AGP Controller
Device ID: PCI\VEN_1039&DEV_0001&SUBSYS_00000000&REV_00\3&61AAA01&0&08
Driver: C:\WINDOWS\system32\DRIVERS\SISAGP.SYS, 5.12.0001.2010 (English), 4/14/2008 01:36:40, 40960 bytes
DirectX Components
ddraw.dll: 5.03.2600.5512 English Final Retail 4/14/2008 12:00:00 279552 bytes
ddrawex.dll: 5.03.2600.5512 English Final Retail 4/14/2008 12:00:00 27136 bytes
dxapi.sys: 5.01.2600.0000 English Final Retail 4/14/2008 12:00:00 10496 bytes
d3d8.dll: 5.03.2600.5512 English Final Retail 4/14/2008 12:00:00 1179648 bytes
d3d8thk.dll: 5.03.2600.5512 English Final Retail 4/14/2008 12:00:00 8192 bytes
d3d9.dll: 5.03.2600.5512 English Final Retail 4/14/2008 12:00:00 1689088 bytes
d3dim.dll: 5.01.2600.0000 English Final Retail 4/14/2008 12:00:00 436224 bytes
d3dim700.dll: 5.03.2600.5512 English Final Retail 4/14/2008 12:00:00 824320 bytes
d3dramp.dll: 5.01.2600.0000 English Final Retail 4/14/2008 12:00:00 590336 bytes
d3drm.dll: 5.01.2600.0000 English Final Retail 4/14
More about : geforce 5500 problem
a b Î Nvidia
July 25, 2009 3:53:15 PM
The fact your system is showing no information for the card indicates no drivers are installed, or the installation is corrupt.
Uninstall the current drivers and back off to the 169.XX series.
You may suffer FSX on that system, but not play it.
August 23, 2009 1:45:26 PM
My card is working again! I just reinstall window.
a c 168 Î Nvidia
October 21, 2011 10:34:51 AM
This topic has been closed by Mousemonkey
