SYSTEM USAGE FROM MOST TO LEAST IMPORTANT: Office work - writing, desktop publishing, PowerPoint, spreadsheets, database; Internet surfing; Video Chat; Photo editing; Gaming - more Spore kind of stuff than Grand Theft Auto
PARTS NOT REQUIRED: Keyboard, mouse, monitor (have an HP w2207 I'm happy with)
PREFERRED WEBSITE(S) FOR PARTS: Newegg.com, but open to suggestions
SLI OR CROSSFIRE: Maybe - but don't think I'll need it anytime soon
MONITOR RESOLUTION: 1680 x 1050
ADDITIONAL COMMENTS:
With current (7/4/2009) various discounts and a tool kit - US$766.81
Trying for a good, basic, long-lived computer - and the rewards and challenges of building it myself. Am currently using an 8 year old Dell Dimension 4300 with an added DVD burner and hard drive but with a 1.5 GHz Pentium 4 processor and 512 MB of RAM that just can't handle new software anymore. Want RAID 1 Array for data security.
Intent is to use Windows XP to start while awaiting Windows 7 delivery in the fall, avoid Vista if at all possible. Know that XP won't recognize 8gb of RAM, but my experience with MS says Windows 7 will be another memory hog and that having more RAM will help. Any insight on this would be much appreciated.
If you don't plan to overclock, remove the CPU cooler and use the stock one. Downgrade your CPU a little and get a second 4850.
If you have gaming in mind, go for a second 4850 card. It will be the best investment to do before everything else.
You can get a 4850 for 90$, so go for it.
In that range of CPU power, Phenom II are cheaper and better. Maybe you should go AMD... also you plan to use ATI cards, try to build yourself a Phenom II X3 720 system with 2 4850 cards in Crossfire.
That's the PC I got and I am really impressed by the power for a mere 165$ of graphic power.
Message edited by redgarl on 07-04-2009 at 11:33:59 PM
Despite the mb supporting faster RAM there is no advantage in using RAM faster than 800 MHz for C2Q . Focus on getting good quality 800 MHz ram.
The sapphire 4850 is a good card but it is a little noisy . For you purposes you can replace it with a 4770 which is very similar in gfx output but is much lower power consumption so it can use a quieter fan . Noise is always a distraction when working , but not so much in games which tend to be loud anyway .
I presume the cpu fan is all about reducing noise? You wont need it for just cooling when the stock hsf will do fine
Dont be fooled by hig peak wattage ratings . Many cheaper psu are called "600 watt" because they can peak at that level for short periods . Quality units are rated for the level they can maintain 24/7 . Either way the total draw from your build will likely be under 250 watts
