Problem with GPU
Forum Graphic & Displays : Graphics Cards - Problem with GPU
Hello!
I have quite old GPU : Club3D Nvidia Geforce 6600.
Problem is that it's running on high temps.(when i dont do nothing with computer,its temp is atleast 60)(When i play it could go 80 degrees).How can i fix it?Or can i?
Sponsored Links
those temps are just slightly outside of normal temps, I had a 7600GT and temps where a little below that. You can add another case fan but I would personally just leave it alone make sure the temps don't go up any higher.
------------------------------ Recipient of multi-best answer awards and $3 power ball winner!!
Reply to ct1615
so no overcloking?
Reply to hents1230
you over clocked your video card?
Reply to ct1615
hehe ive been making this suggestion a lot lately. cant hurt to go at it again.
strap a fan to your card. on the outside. make sure it directs air into the hole that your gpu fan is in. make sure it directs air in the same direction. i crazy glued a casefan to a dying 8800gts, it now runs cooler and overclocks better than it EVER did before. its not pretty, but its effective. the higher rpm the fan you add on, the better.
http://www.overclock.net/gallery/d [...] 190021.JPG
something like that, tho it doesnt have to be quite so ugly. mine looks considerably better. ^^
*edit* scratch that, i just noticed your videocard doesnt have a sheath. (a plastic cover.)
Message edited by neon neophyte on 07-25-2009 at 11:14:16 PM
Reply to neon neophyte
yeah it doesnt,but great idea thought.i must think about it.maybe ill just add some fans to computer.got none exept for cpus and gpus.and ofc psu
Reply to hents1230
hey, im considering tossing a fan on my NEW gtx285, just cause.
Tom's Hardware > Forum > Graphic & Displays > Graphics Cards > Problem with GPU
There are 1170 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
