I built my rig in Feb and really went all out. The only problem is, no matter what I do, my temps are always too high. I've tried using just the dot in the middle and also spreading the compound and it didn't make a lick of difference. I've tried all kinds of OC guides and still no dice. Is it possible I just got a really hot 2600k?
I see people posting their idle/load temps and voltages and I can't believe it. maxing out at 65c @1.35ish volts? **** that, the best I can do is 80c. In fact, that's what I've been doing till now. Just keeping it under 81c and accepting it. Well I'm sick of it. I want a cool running PC too.
Its messed up cause i can have it running stock and temps max out around 73c. 4.2ghz is 75c. 4.5ghz is 80c. 4.6ghz is 81c. And my voltage? It HAS to be at or above 1.350 if i go past 4.2ghz.
Here is my setup. Someone ****ing show me the way! If i cant get temps in line with everyone else's then it must be this pos mobo or a hot cpu. Thanks.
2600k
corsair h70 with dot method at the moment
miv extreme b3
ripjaws 1600mhz
gtx 580
800d with about 7 fans
and i just wanna say i know there are a million of these threads but everytime i have tried asking for help in someone elses thread i get b****** at or it gets passed up. once i have a definitive answer to what i should do for my particular situation ill delete this thread
i have a 5000 dollar amazon card standing by so if i need some high class water cooling or i should try another 2600k, say so!@ i dont care
2600k
miv extreme b3
ripjaws 1600mhz
gtx 580
