Which mem should i go with? Already ordered the other parts need impu
Should i go with this:
G.SKILL Ripjaws Series 4GB (2 x 2GB) 240-Pin DDR3 SDRAM DDR3 1600- $94
or any of these GSkill Eco Series Ram Modules?
Plan on using this MSI P55-GD65 mobo with a radeon 5850 for gaming and i plan on overclocking eventually. thx for any imput
or if anyone knows of any other ram that would be more suitable i would use that...
I would really appreciate the help. I ordered all of the other parts already and im waitin on the ram bc i dont know what to do
5 answers Last reply
More about which with ordered parts impu
  1. This are better that the RAM that your post.
    http://www.newegg.com/Product/Product.aspx?Item=N82E16820148327
    try to get a RAM memory with CL7 or CL8
  2. i would grab those but im already over my budget and im lookin for something with lower voltage bc apparently voltages over 1.65v will burn out my processor
    1.65V burn out your processor?, the voltage problem is 2.0V or more.
  4. i cant find the post but someone told me that voltages >1.65 are bad for this particular cpu
    1.65V are bad not only for your CPU, this voltage can burn out any CPU. The max votage that you must apply to your CPU is 1.5V, BUT the voltage of your RAM DOESN'T HAVE RELATION WITH THE CPU VOLTAGE.
Memory DDR3 RAM Product
