Solved
Sapphire Radeon HD 6850 overclocking help
Hello guys, after succesfully overclocking my CPU to 3.6Ghz (a AMD phenom II x4 940), I am now wanting to overclock my Radeon 6850. I will use the Trixx Sapphire Tweal Utility to overclock this card, but I am a noob at overclocking videocards :cry: . Everything right now for my card is on stock settings. (pic is included showing my temps and some other stuff).
I would like a nice performance boost (Anything to help run the upcoming game Battlefield 3 :p). Any help and suggestions will be welcome. Please and thank you
6 answers Last reply Best Answer
More about sapphire radeon 6850 overclocking help
  1. What resolution are you using? I recommend use MSI Afterburner.
  2. 1680*1050 is my resolution
  3. Best answer
    The stock settings can give you all that you need, overclock will not make a much difference at that resolution.
  4. same goes for vid cards as does for cpu's. The memory clock is pretty easy to start with. gradually bump it up in 10-20mhz increments and run a benchmark like 3d mark.(I am against running furmark as it places unnatural stress on the vidcard and can cause them to fail.) you should get to a stage where things either crash, or you get ramndom screen artifacts. once you reach this point back off the clocks till its stable. once you have one of the clocks stable, now change the other. You should forget about voltage increase for the time being. Read some 6850 reviews, reviewers will tell you the approximate max frequencies they were able to achieve. this will give you an approximate limit, although every chip is different.
    You sure?
  6. Best answer selected by che3zeman.
Graphics Cards Overclocking Sapphire Radeon
