Tom's Hardware > Forum > Homebuilt Systems > New System Build > HELP FOR MY NEW BUILD
Forum Homebuilt Systems : New System Build - HELP FOR MY NEW BUILD
Hi , i recently built a new system and i am having some problems :
Build :
ANTEC 1200 casing
Evga X58 E757 Mainboard
Intel Core i7 D0
6GB Corsair dominator CL8 1600mhz
ocz Vertex 60gb
3 WD caviar balck 1TB
CoolerMaster V8
Bluray rewriter
Dvd+-R writer
Sapphire Vapor-X Toxic Hd4890
Asus Xonar STX
I am currently using a Viewsonic 17'' monitor for 3-4 months till i get the DX 11 cards and get a 32'' one
I went to the bios..i put ( dummy overclocking - on )
I changed only the ram setting to xmp 1 ..it automatically o'c my processor to 3.2ghz..but the pc keeps restarting.
My processor and ram are running @ default settings
How to o'c my i7 to 3.2ghz atleast and ram to 1600mhz safely ?
Is there any good and reliable program to check the temperature of all my parts ?
On the mainboard there is a cpu temp display ..
When i first put it ..it stayed 23 for a few seconds then went on drastically to 45 , 72 , 85
FInally it remains @ 7F
What does the 7F means...?
I installed a vista ultimate x64 and had some problems :
1 . Cant get resolution above 1280*1024
I thought it was the screen but i had managed to get better resolution on an xp x64
Screen was VGa only so i had to use the DVI converter that came with the sapphire radeon hd4890
2. When stating pc and running 3d benchmark ..both detects all my hard disks bt when i click on my computer i get only the ocz vertex and 1 WD 1tb
When i should be getting 1 ocz vertex and 3 WD hard disk
3. Should i stick with vista or use the latest windows 7 Rc x64 ?
What other difference bet windows x86 and x64 except that the x32 detects only 4gb ram?
Thanks
Sponsored Links
I have a 5.9 Windows Exprerience Index
Is that ok or should it have been better for that system ?
Reply to Viruzzz
17" doesn't really tell me anything about your monitor. CRT? LCD? Model number?
7F is probably an error code.
Some utilities
CPU-Z
Real Temp
HWMonitor
Do you have a RAID configured?
------------------------------ My Guide to choosing parts
A big list of recommended parts
Troubleshooting Guide w/links
Reply to Proximon
5.9 is the max WEI.
reseat your heatsink, you have temp problems.
17" monitors max out at 1280x1024 so you can't go any higher, but why are you using such a rubbish monitor with such a powerful build anyway.
Reply to Helloworld_98
- 0 +
Viewsonic 17'' Lcd VA702
Is the EVGA E-Leet that came with the motherboard reliable ?
Reply to Viruzzz
CNET says the max resolution is 1280x1024 for that monitor.
- 0 +
Damn...i need to get the 32'' sooner
Urgent :
Vista Ultimate x64 Sp2
or
WIndows 7 build 7264 ( or another build ) x64
Reply to Viruzzz
There are no 32" monitors that I know of. If you are getting a 32" TV, then you will be limited to 1920 X 1080.
Get Vista with a free upgrade to Windows 7:
http://www.newegg.com/Product/Prod [...] 6832116677
Reply to Proximon
- 0 +
Cant get better resolution on a full Hd tv 1080p 6ms response more than 30'' ?
Lg 32'' 1080p Lcd
http://www.newegg.com/Product/Prod [...] 6889005063
http://www.newegg.com/Product/Prod [...] 6889005064
Reply to Viruzzz
If you want a 32" screen, I think that's great. I just wanted to point out that they don't have any greater resolution than a 24" monitor. You were referring to screen size rather than resolution.
Your video card doesn't care how big the screen is, just what resolution is needed.
32" TV: 1920 x 1080
24" monitor: 1920 x 1080 OR 1920 X 1200
Reply to Proximon
- 0 +
What is better ..o'c the processor to 4.0ghz with turbo mode and hypertreading off or leaving it @ 2.6ghz with turbo mode and hypertreading on ?
Reply to Viruzzz
32" TV: 1920 x 1080
30" monitor: 2560x1600
Reply to mindless728
- 0 +
sorry to bump in, but when lets say a monitor is 1920x1080 does that mean it can also be lowered to 1680x1024 when playing games
Reply to K1ash3r
Get a gaming monitor there are several available if you want a higher resolution than 1080, they are 30" standard and are a max of 2560x1600. Something smaller on sale is Newegg has 24hr deal on a 27" Hanns-G on Newegg for $299 and is a 3ms, HDMI in, 1920x1200 resolution. The 2560x1600 monitors are a BIG jump in price (from Dell, Apple, and a Nice LG here: http://www.newegg.com/Product/Prod [...] 6824005115 at only $1,150.
You can write off getting a 30" if you also plan on having a TV Tuner, Blu-ray drive, etc. as thats a nice size for any bedroom.
EDIT: to K1ash3r, most games have 1920x1080 as a resolution to select from, I can't think of any new game that doesn't. If not you can run at ANY resolution, just change the Aspect Ratio (in the game menu) to 16:9
Message edited by jgmcgowan on 07-07-2009 at 04:04:03 PM
Reply to jgmcgowan
- 0 +
Yep...by going to display setting you can change to other resolution..
Do anyone know any good windows for a powerful system?
What difference bet. 64-bit and 32-bit except :
The 32-bit detects only 4gb Ram
64-bit color
I dnt realy like the windows x64 as the colors arent that good ....like white spots across the screen,..The 32-bit have better colors
Reply to Viruzzz
- 0 +
64-bit color
Well I know that win7 and vist support DX10 unlike xp
Reply to K1ash3r
- 0 +
The windows 7 build 7264 does not detect my sapphire hd4890....
Trying windows vista ultimate sp2 x64 now
Reply to Viruzzz
- 0 +
hey can you give me a link from where I can downlaod vista x64
Reply to K1ash3r
- 0 +
viruzzz.. you da man =) ty
vist 64bit ultimate right?
Message edited by K1ash3r on 07-07-2009 at 05:52:32 PM
Reply to K1ash3r
@viruzzz, you know that's illegal, right?
x64 changes the memory interface, not colour interface.
- 0 +
Yep ...vista ultimate sp2 x64..
Download hj Join ..you will need it
Reply to Viruzzz
- 0 +
wats hj Join and what do i need it for?.
Reply to K1ash3r
once again, if you download that you will be downloading illegal material, you have not bought the software.
if you want vista x64 then either get it off MSDN or buy it, otherwise I'm pretty sure any other method of getting it from a consumers perspective is illegal.
- 0 +
im just downloading the vist in case my win 7 doesnt work because I wasted like 9 DVD's before i finaly got the win 7 on a DVD.
Reply to K1ash3r
^ it's still illegal, no matter what reason.
- 0 +
hey do you have a link for vista basic 64 bit as well?
Reply to K1ash3r
- 0 +
Send me your email and i'll send you the links but the ultimate is better ....
Reply to Viruzzz
- 0 +
well Ill be using my pc for gaming so I dont think I need the extra software, and wkat makes ultiamte better?
Reply to K1ash3r
- 0 +
Hey i'm having problems with mt pc...worked well for some time...temp around 22 degrees ..then suddenly blue screen ..physical memory dumping
Then pc restart and says windows cannot start ..insert windows cd and press repair etc....
My mainboard makes ticking sound ..i thought it was my graphic cards whick the 4 very small light went on and off but even after removing graphic cards and sound card ..still get the ticking noise..
The cpu temperature screen on the mainboard shows f3 , f6 etc instead of 20 degrees....HELP PLZZZZZ
Reply to Viruzzz
- 0 +
The f3/f6 are
Post Port Debug LED and LED Status Indicators
Post Port Debug LED
Provides two-digit POST codes to show why the system may be failing to boot. It is useful during troubleshooting situations. This Debug LED will also display current CPU temperatures after the system has fully booted into the Operating System.
BUT I CANT FIND THE TROUBLESHOOTING GUIDE TO THESE CODES>>>>>>
Reply to Viruzzz
- 0 +
My sapphire Hd4890 toxic runs Extremely hot...is that normal ?
Reply to Viruzzz
- 0 +
My hd4890 still runs extremely hot..but the real problem came with the asus xonar stx ...I removed the card and Pc is working great thought i used to get better FPS before/// Any reason why there was a drop in my fps ?
Reply to Viruzzz
There are 1183 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
