Here's the situation. I'm working out a build for a machine that will be used for audio editing/mixing so silence is paramount. Since there will also be heavy amounts of processing keeping the CPU cool is also very important. The problem I'm running into is space. I'm planning on getting the
Silverstone Fortress FT02 case
The Gigabyte Z68X-UD5-B3 LGA 1155 Motherboard
The Intel i7 2600k
the corsair vengeance ram
Since I'm using all the ram slots (with tall ram) I'm having issues finding a good cooler that will fit in the space. I'd like to try and keep the cost under $50 for the cooler but could go a little over if absolutely necessary.
a couple I've looked at are the Thermalright mux-120 and the cooler master 212+
I'd really appreciate any suggestions/feedback.
Thanks
The Intel i7 2600k
Thanks
