Hey all. I'm new to computer building and I'm looking for some advice on just about everything from what mobo to use to the case. If anyone has any advice i need help with mobo, power supply, graphics card, memory, case, heat sink, hard drive, optical drives, ect... Having said that, I'm planning on running windows 7 64 bit and this is going to be primarily a gaming pc but i also plan on using photo shop and a couple other programs like that. I've looked around on newegg and saw a lot of great product but my fear is ordering parts that arent compatible or up to date. thanks for all the help I'm sure I will soon get...
Message edited by jcocanour on 10-07-2009 at 06:28:16 AM
Scroll down the center column until you come to the Build Your Own section. There are three different system marathon game builds at three different price levels. Each build has a complete list of compatible parts.
*Intel Core i7-860 Lynnfield 2.8GHz 8MB L3 Cache LGA 1156 95W Quad-Core Processor
*GIGABYTE GA-P55-UD3R LGA 1156 Intel P55 ATX Intel Motherboard - $420 combo
http://www.newegg.com/Product/Comb [...] mbo.270433 -- The 860 is just as good as the 720, but will save you money on the Mobo and RAM
For the power supply, anything over 500 watts will work and also from Corsair, Thermaltake, OCZ, or PC. And for the dvd+rw, any brand will work for the most part.
Thanks for the post. I checked out your suggestion and they all look great but none of them had I7 cpu's. Any other ideas.
I like the Rosewill R5601 case over at NewEgg. The ports on top are easy to get to, it has a spring loaded flap for the CD drive, side facing HD slots (with zero screw rails for your drives!), two 120mm fans... and the base has raised mount points so you can screw your ATX motherboard to it without having to use stand-offs (which they provide in case you were to need them)
