Asus gtx 260 sli overheating problem
Graphics card Expert
It possible its not a graphic card problem usually when the card heats up the drivers stop responding, but if the memory is bad on the card that could cause it to bsod. What are your gpu temps on idle and load? Cpu temp? Try 1 memory stick at a time its possible a stick went bad.
i had the same problem. some time ago, i ordered 2 evga 8600gts, id put them in an sli and after a few minutes the computer would freeze. id open the case to see one being really hot, and one cool. i took out the defective one and the single gpu worked fine. maybe its just your gpu thats defective?
try just running the computer with the bare minimums, 1 stick of ram , 1 gpu...
Ask the community
