Monitor help
Forum Graphic & Displays : Nvidia - Monitor help
Hi im zach
I just built a pc: cpu-e8400 hd-640gig(sata) vidcard-7900GS ram-4gig(g.skill) case-Antec300 mobo- gigabyte ep43 *use an old crt because i am a gamer*
anyways thats my set up, I put it together and when i start it up the monitor does not turn on, The video card is turns on, im like 90% sure its the f panel on the mobo i been messing with it for hours, i tryed alot of things, I am just hoping someone here will say something i have not done yet that works :lol:
Thank you, all help is VERY appreciated. * going from a stock gateway from 2001 to that set up :D *
Sponsored Links
Thats a really, really, really poor gfx card to put in a rig like that.
However, I assume that nothing is displayed at all including bios post and things like that?
I am assuming also that you have tried different cables and tested the monitor with another computer yes?
------------------------------ I'm a git, deal with it.
Antec 1200,PC Power & Cooling 750,Gigabyte DS4-x48,Intel Q9550@3.4 W/Xigmatek S1283,8GB OCZ DDR2 800,ATI 4870X2,X-FI>CA 640C amp>Tannoy R300/Senn 595's
Reply to strangestranger
Yes nothing show's up. and yes im using that monitor on this pc right now. Like i said, im pretty sure its the f panel on the mobo, but not sure i was messing with it alot lastnight and im still not sure where each cable go's for sure in it.(f panel)
Reply to zgilbert420
Front panel on the mobo??? wtf???
Did you plug in the monitor to the vga output?
------------------------------ 550 @ 4.0 Ghz 1.425v
BFG GTX 260 (216)
4GB G.Skill @ 960MHz
Thermaltake TP 850w
Reply to OvrClkr
If your monitor is plugged to the VGA output of the 7900GS and you have no signal, make sure you have the card in the correct pci-e slot. If that doesnt work then make sure the fan on the video card is spinning and try that same video card on another pc if available.... If all else fails you either have a bad monitor or a dead video card.....
BFG GTX 260 (216)
Thermaltake TP 850w
Reply to OvrClkr
Yes the monitor is plugged into the VGA output(tryed both slots aswell) yes the card is in the right slot, and yes the fan spins, ill try it on a diff pc right now, the monitor isnt bad im using it right now.
Ok, let me know if the video card works on the other PC....
BFG GTX 260 (216)
Thermaltake TP 850w
Reply to OvrClkr
lol found out i dont have any extra power cables in this comp for the vid card, so i cant check it.
So that video card requiers a 6 pin connector? Doesn't it use a 4 pin Molex like this one?
http://www.newegg.com/Product/Prod [...] 6814150224
BFG GTX 260 (216)
Thermaltake TP 850w
Reply to OvrClkr
I ain't sure which cables on the f-panel(I assume it is where the power button and reset button wires go to yes?) would be needed for the monitor to work.
Where did you get the gfx card from, I doubt new so is it carried over from your last comp?
What does the front panel cables have to do with the monitor?????
BFG GTX 260 (216)
Thermaltake TP 850w
Reply to OvrClkr
this is the vid card, its 6 pin * http://www.newegg.com/Product/Prod [...] 6814130057 * no i bought it from a friend. and my teammate was telling me it could be the f panel since it was hooked up wrong, but than again when i think i hooked it up right it still didnt work. So im not sure.
You have a horrible friend.
Well, he sold you an extremly poor card which may be dead.
I hope you didn't pay more than a few dollars, twenty tops for it.
Ok, do you know when the card was purchased? Is it still under warranty?
BFG GTX 260 (216)
Thermaltake TP 850w
Reply to OvrClkr
Ya im sure ill get my money back and just get another.. oh well :/
... If you RMA the card, you most likely will get an 8800 or higher, 7900GS are out of stock, even the refurbished ones...so hurry up and send it in....
BFG GTX 260 (216)
Thermaltake TP 850w
Reply to OvrClkr
Tom's Hardware > Forum > Graphic & Displays > Nvidia > Monitor help
There are 815 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
