How to mount power supply
Forum CPU & Components : Power Supplies, PC Cases & Case Mods - How to mount power supply
getting a antec 1200 and a
CORSAIR CMPSU-850HX 850W ATX12V 2.3 / EPS12V 2.91 80 PLUS SILVER Certified Modular Active PFC Power Supply
I am not sure how to mount the power supply... the case has the PS at the bottom, not top. I know which part of the PS is at the back of the case ie the part with the power plug and switch (Captain Obvious!!!) but not totally sure if the large fan needs to point up or down inside the case. if its pointing up, won't it be sucking hot air from the CPU and cooler, but if down, won't it be sucking air straight from a flat surface???? not sure if my question makes sense...
can anyone help?
Sponsored Links
makes little or no difference. I have mine mounted fan upwards in my Antec 1200... bit pointless having the fan facing down as there is minimal room under the PSU and no bottom vent on the floor of the case
Reply to ulysses35
^5 +1 what ulysses35 said. In your case the psu should be mounted with the fan on top. Yes it will pull in warm air from the case and exhaust it out the back of the case. That is a typical configuration. It's okay! Don't worry! Be happy!
Reply to JohnnyLucky
I have Antec 900 cases. I mount the PSU with the fan facing up. The only things generating heat in the bottom of the case are the two or three hard drives mounted in the lower drive bays.
HD temps in the case with three drives (one WD 640 Black and two 1 TB Greens) have never exceeded 29 C. and PSU exhaust air is about 3 C. over ambient. The other fans handle the CPU and GPU temperatures.
Reply to jsc
What? It makes a HUGE difference. You want the fan facing up so it can draw air down and out.
Message edited by zipzoomflyhigh on 10-08-2009 at 08:52:43 PM
Reply to zipzoomflyhigh
zipzoomflyhigh - I think that first part was in response to the OP's comment about the psu fan sucking in warm air from the cpu. At least that's the way I interpreted it and ulysses35 did mention that it was pointless having the fan facing down.
Message edited by JohnnyLucky on 10-08-2009 at 09:46:23 PM
I am curious now, I have a CM690 which has vents at the bottom of the case. If I want the PSU to remain cool, don't I want to mount it fan down? I thought that is why they put it there.
Confoooossseeeddd
------------------------------ How To Ask for Build Advice
Intel I7 860 @ 2.8Ghz - CM Hyper 212+ - Asus P7P55D Pro - HIS Radeon HD 5850 - WD Caviar 160&320 GB - Samsung SH-S223B - CM 690 MidTower - CM 700 SilentPro
Reply to era86
era86 - Mounting the psu fan side down over an opening in the bottom of the case is an option. The concept is that if there is sufficient ventilation, air flow, and cooling for all the components in the system, then the psu can be mounted fan side down so it can draw in fresh air and cool itself. One just has to be careful not place the case directly on the carpet as it could block air intake. A few years ago I built myself a custom pc stand with casters. Carpet problem solved and I can move the pc very easily.
Just to avoid confusion, the Antec 1200 does not have an opening in the bottom rear of the case while the CM 690 does.
Message quoted 1 times
Message edited by JohnnyLucky on 10-08-2009 at 09:48:41 PM
Ah... thanks JohnnyLucky... that clears it up. The CM 690 actually has nubs at the bottom of the case to prop it up off the carpet. That explains alot.
Reply to era86
JohnnyLucky wrote :
Just to avoid confusion, the Antec 1200 does not have an opening in the bottom rear of the case ...
A few minutes work with a Dremel tool or nibbler will fix that.
Reply to jsc
jsc - hehehehe - I use a hole saw attached to my electric drill. :)
Tom's Hardware > Forum > CPU & Components > Power Supplies, PC Cases & Case Mods > How to mount power supply
There are 831 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
