Hi
Thanks to this forum i realized that building your own pc was not so dificult, so i did my first build with the following components:
1 COOLER MASTER Sileo 500 RC-500-KKN1-GP Black Computer Case
2 ASUS M4A785TD-V EVO ATX AMD Motherboard
3 Rosewill Green Series RG430-2 430W "Compatible with Core i7, i5" Power Supply
4 AMD Phenom II X4 905e 2.5GHz Socket AM3 65W Quad-Core Processor
5 Crucial 4GB (2 x 2GB) 240-Pin DDR3 SDRAM DDR3 1333 (PC3 10600) Dual Channel Kit Desktop Memory
6 HD 500G|SEAGATE ST3500418AS
7 DVD BURN SONY|AD-7240S-0B
Everything went ok and works perfectly, except that when i use a program called cpu-z and i notice that memory is running at 666 instead of 1333?
After this, i got into my motherboard bios, and after looking at all options i only found the following options regardinf mem speed: 2someting, 4something, 666 and 800.
Can someone please point me in the right direction on how to achieve 1333. I dont know anything about cas latency, timings, etc.
Thanks
Thanks
