Codegen 450w PSU problem!?!?!
Forum CPU & Components : Power Supplies, PC Cases & Case Mods - Codegen 450w PSU problem!?!?!
Why does this PSU not have any PCI-E power connectors!!. I need one but this PSU seems to have none. The model is the 450x.
Thanks in advanced fro your answers
Sponsored Links
It's an old design for older computers. The key to that is the relatively heavy 40 amp 5 volt rail and the really light 16 amp 12 volt rail. 16 amps is not enough to power a medium powered CPU and graphics card.
Compare the specs with a 400 watt 400CX Corsair with its 30 amp 12 volt rail.
Reply to jsc
It seems to run my q6600 and GTS 250 fine though???
Reply to hestermofet
You have very little reserve capacity left. A stock Q6600 pulls about 7.5 amps @ 12 volts with all four cores loaded to 100%. OC'd to 3.6 GHz, it pulls 9.5 amps. (I have a Q6600 and I measured it with a lab calibrated clamp-on DC ammeter.)
A GTS250 pulls about 8.5 @ 12 volts amps under a heavy 3D load.
You apparently haven't loaded your system heavily enough. Your first sign of trouble will be apparently random reset and reboots under heavy graphics loads.
Reply to jsc
I agree, you need a quality PSU. Just because it runs your rig now doesn't mean it won't fry the whole thing tomorrow.
Reply to leo2kp
I know codegen, i classify them as "no name" brand. They may work fine for light PCs, but i wouldn't use it to supply power to a system i'm proud on or consider to be of importance.
------------------------------ ...man will occasionally stumble over the truth, but usually manages to pick himself up, walk over or around it, and carry on.
Reply to sub mesa
Tom's Hardware > Forum > CPU & Components > Power Supplies, PC Cases & Case Mods > Codegen 450w PSU problem!?!?!
There are 708 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
Related Content
  • 01:00 Conrad925 won the Freshman badge
  • 01:00 skythra won the Freshman badge
  • 01:00 Ckaz won the Freshman badge
  • 01:00 james59 won the Uniformed badge
  • 01:00 snarl won the Uniformed badge
  • 01:00 patlabor44 won the Uniformed badge
  • 01:00 Kiren won the Uniformed badge
  • 01:00 WookinPaNub won the Uniformed badge
  • 01:00 kwadams won the Uniformed badge
  • 21:57 brockh won the Sophmore badge
