Tom's Hardware > Forum > CPU & Components > Power Supplies, PC Cases & Case Mods > [Solved] Best case- under 300, no door, 8 or more internal HDD bays?
Forum CPU & Components : Power Supplies, PC Cases & Case Mods - [Solved] Best case- under 300, no door, 8 or more internal HDD bays?
Best answer from era86.
Title says it all. Am considering the antec 1200 but am learning that with the 5870 installed, it is too long and then must give up a drive bay or two.
Looking for non-1200 recommendations. Bling okay but could take or leave it. Excellent cooling a plus
I'm pretty sure all of these have enough room to fit the 5870, but as far as their width, you might have trouble fitting a large CPU HSF in them. Check the dimensions of your CPU HSF and these cases.
Other than thay, they have 8 or more HDD bays, excellent cooling, and run under 300.
LIAN LI PC-A70B
http://www.newegg.com/Product/Prod [...] 6811112141
LIAN LI PC-B70
http://www.newegg.com/Product/Prod [...] 6811112224
LIAN LI PC-A70F
http://www.newegg.com/Product/Prod [...] 6811112243
Sponsored Links
Best answer
LIAN LI PC-A70B
LIAN LI PC-B70
LIAN LI PC-A70F
------------------------------ How To Ask for Build Advice
Intel I7 860 @ 2.8Ghz - CM Hyper 212+ - Asus P7P55D Pro - HIS Radeon HD 5850 - WD Caviar 160&320 GB - Samsung SH-S223B - CM 690 MidTower - CM 700 SilentPro
Reply to era86
Lian Li cases are really top notch but if you looking for something with a little more design to it then I would suggest you look at the Coolermaster Cosmos S. It has plenty of room for whatever you want to do with it.
------------------------------ When searching for Bearded Clams whatch out for those Crabs
Reply to smokinu
Lancool is a subsidiary of Lian Li. Two months ago they introduced a new line of Dragon Lord cases. They come with and without the bling. The lower drive cage can be rotated 90 degrees which would be a big help with those extra long video cards. Here's a link to a web page showing the different models:
http://www.mwave.com/mwave/deepsea [...] &ALL=y&TP=
Here is a link to a video review done by the guys at mnpctech.com:
http://www.youtube.com/watch?v=U2MdUGxWEcU
Message edited by JohnnyLucky on 10-08-2009 at 08:56:40 PM
Reply to JohnnyLucky
There are 1094 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
