Raid Card Help: LSI 9260-8i
Last response: in Storage
I recently bought a LSI 9260-8i
It has a 16 pin connector for individual drive faults. I was just wondering if anyone knew of a connector for this type of connection, or if ppl just individually connect seperate leds to each set.
The connector is labeled as JT12 in the card diagram in case any of you look at it.
Thanks for your time.
More about : raid card lsi 9260
What you got is SAS raid controller
It has TWO SFF-8087 connectors, which has side-band connection for direct connect to SAS/SATA back plane. It does more than just connect to SAS/SATA drives
Use this cable for back-plane connection
SFF-8087 to SFF-8087
If you do not have backplane, but individual SAS/SATA drive then use this
SFF-8087 to SAS/SATA cable
Hope this help
Ask the community
