G
Guest
Guest
Hi there.
My problem is simple enough to explain: I had a new 2TB sata drive that I was using externally for a few months, then I decided to add it internally alongside 3 drives that I was already using internally. I used one of those 1 molex to 2 sata power splitters to add to use the same molex power connector as one of the existing sata drives, which previously had a single molex/sata adapter.
The problem arose when I powered the system back up, or tried to. It wouldn't boot to POST, just spun the fan once and died, though the front panel LED stayed on. This behaviour continued till I removed both drives on that splitter. Now neither drive will spin up at all; I tried with an external power source as well from a USB adapter. And I mean they don't even try to spin up, no clicking, nothing. It's like plugging into a brick.
So my question is, is there anything I can do to resurrect these drives? I'm willing to write them off and put it down to experience if I have to (there was nothing essential on them, but together they made 3TB and it's annoying to lose the storage space), but a quick scour of the web suggests this isn't a common situation, most seem to suggest these splitter cables are safe to use. Any comments or suggestions would be appreciated. Thanks.
