Tom's Hardware > Forum > Graphic & Displays > Nvidia > Will a Palit GTS 250 1Gb work on my system?
Forum Graphic & Displays : Nvidia - Will a Palit GTS 250 1Gb work on my system?
Hi im going to buy a pailt gts 250 to upgrade from my old sparkle 8600 gt
Will my system support it?
My PC Specs:
AMD Athlon 64x2 Dual Core 4200+ 2.2GHz
PQi 4 GB Ram [DDR2]
Sweex 650w PSU
Gigabyte GA-M55SLI-S4 [nForce Chipset] - (Has 2 x16 Pci-Xpress Slots)
1 Samsung 300 Gb HDD, 1 Samsung 160 Gb HDD, 1 Lacie 500 GB External Hardisk
Please do not offend me or call me noobish im a new comer thx :D
Sponsored Links
Yes, it will work. CPU is going to be a bit of a bottleneck though. What are you upgrading from?
------------------------------ CPU: Q9550 at 3.6ghz (FSB 425mhz) | MB: P5E3 Premium | Ram: 4*2Gb Corsair DDR3 @1417mhz | GPU: 2 HD4890 1Gb (925core/1025mem) CF | PSU: OCZ ELiteXtreme 800W | Sound: Creative Titanium Fatal1ty Pro | 2*120gb OCZ Vertex SSD Raid0 and 2 500gb Raid0 HDDS
Reply to daedalus685
I currently have an 8600 gt ddr2 sparkle
Reply to steve7
You will surely notice a good jump in performance then.
The GTS 250 will run just fine with your hardware, no worries.
Just one point, though. The CPU is a little weak to drive the GTS250, I would advise either a 9600GT or HD4670 would be a better match, and probably cheaper.
------------------------------ Peace cannot be kept by force, it can only be achieved by understanding: Eienstien
Reply to coozie7
if I buy a AMD Athlon 64 X2 Dual-Core 5400+ or 6000+ will it be better?
Reply to steve7
It will be an improvement, obviously the faster the processor the better but before you make a decision first:
Download and run CPUZ and open the 'motherboard' tab, this will tell you exactly which motherboard you have and, importaintly, if it is AM2 or AM2+, that little '+' is importaint and if you have a AM2+ 'board that will open up a wider range of upgrades.
Once that is done, check this list, it will tell you which processors your motherboard will support:
http://www.gigabyte.com.tw/Support [...] uctID=2310
Reply to coozie7
[img]C:\Documents and Settings\Steven\My Documents\My Pictures\untitled.JPG[/img]
Reply to steve7
[img]undefined[/img]
Reply to steve7
how can i upload a picture i need to show uw something on cpu-z
Reply to steve7
Hi i ran cpu-z in the tab of mainboard it doesnt show am2 or am2+ :S
Reply to steve7
Then assume AM2, an AM2+ chip will be restricted by the slower memory access given by AM2.
Reply to coozie7
but the 5400+ and 6000+ are AM2 not AM2+ :S
Reply to steve7
Yes, you are correct.
So to recap: Yes, your hardware fully supports the GTS250. Should you wish, a faster processor will give the card more performance but bear in mind, the X2 6000 takes your motherboard to the limit of its official support.
A faster card (HD4870/GTX260 or beyond) is likely to cause issues with the powersupply, despite its 650W output, the importaint +12v amperage is quite low.
Message edited by coozie7 on 07-31-2009 at 07:51:14 PM
Reply to coozie7
no im not gonna buy a GTX 260 or beyond. Thx for reply I think GTS 250 is going to be enough. Pls specify by x2 6000 takes my motherboard beyond the limits of its offical support. Do u mean to tell me that my motherboard wont support the 6000+?
Reply to steve7
No, it will support the 6000+ and I misread the CPU support list, it will actually go all the way to a X2 6400+ Windsor cored unit.
Reply to coozie7
There are 1214 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
