Maybe it's a bit more than a slight problem, though.
Anyway, I've been meaning to ask this for a while. A month or two ago, I thought I'd try out overclocking my nVidia GT330M. This worked fantastically for the first few times (I was pulling around 20 FPS with everything on the Mafia II demo maxed, at a 1366x768 (My laptop's native res) resolution). Temps also generally stayed below 70. However, from then on, it just seems to lower FPS. A lot. When I have it overclocked now, even on medium settings my frame-rate tanks to around 5-8 FPS, and I can't quite put my finger on why it's happening...
I've stayed away from it since then, but I was wondering if anyone knew why it began to do that? Stock clocks get the same FPS as they did before, so performance of the card isn't inhibited in any way.
