Tom's Hardware > Forum > CPU & Components > Power Supplies, PC Cases & Case Mods > Need a little help between 2 power supplies!
Forum CPU & Components : Power Supplies, PC Cases & Case Mods - Need a little help between 2 power supplies!
Alright guys, looking for a little help, I am wanting to choose between these two power supplies,
http://www.tigerdirect.com/applica [...] etailspecs
http://www.tigerdirect.com/applica [...] CatId=2534
please help, i am going to get an ati hd5850 card, possibly crossfire 2 of them, which one would be better, My rig is an x58 chipset, i7-920 processor, 6x1gb ddr3 1333mhz, 1 hardrive, current gpu is ati 4850 512mb.
Sponsored Links
Of the two PSU's listed, Corsair.
Reply to jsc
is there one better than the two at that price range?
Reply to feroc1ty
This one is $10 cheaper and has free shipping. I have this one. Only complaint is that the ribbons ( cables ) are a little stiff. Works great.
http://www.newegg.com/Product/Prod [...] 6817139009
Reply to swifty_morgan
corsair easily.. the other has 6 12v rails... WOAH! never seen that many before
------------------------------ How To Ask for Build Advice
Intel I7 860 @ 2.8Ghz - CM Hyper 212+ - Asus P7P55D Pro - HIS Radeon HD 5850 - WD Caviar 160&320 GB - Samsung SH-S223B - CM 690 MidTower - CM 700 SilentPro
Reply to era86
6 12 volt rails.. thats like....hrmmm... ROFLCOPTER!!!
lets see I can put a hard drive on this rail... a graphics card on this rail..
whoops I put 2 devices on one rail no wonder my pc wont boot?!!?
LOL..
corsair 1 70AMP rail = win
Reply to rand_79
Ive got the 750W single rail corsair, and its pretty damn good.
Ive managed to lower my CPU voltage from my 650W near-no name brand psu, as this one only drops 0.02v under load.
Always go for a brand name PSU. A bad one can die more easily taking pretty much every component with it.
Reply to mrmez
600W is sufficient for 2x HD5850 at stock frequency in CF, so a Corsair HX620 or HX750 is more than enough.
HX620 Max Overload with it still being within spec : 746W output @115V outlet
HX750 Max Overload with it still being within spec : 912.9W output @115V outlet
The efficiency is even better with 220V outlet!
Reply to andy5174
Yes. Corsairs are pretty conservatively rated. you can pull about 15% - 20% more than rated power across the whole line of PSU's and still stay in spec.
I have a TX750. Anyone else could legitimately call it a 900 watt PSU. And it is rated for full output power at 50 C.
Reply to jsc
I am going to pretty much be doing the same, starting with one 5850 then adding another in the future.
Does anyone know if this PSU is sufficent to support 2 5850:
COOLER MASTER Silent Pro 600
http://www.newegg.com/Product/Prod [...] 6817171036
Its modular, single rail and has 40 amps
At first I was going to get the CORSAIR CMPSU-750TX 750W because it had 60amps, but it is not as silent as the cool master nor is it modular. So its my second choice if the cool master doesnt fit my needs.
EDIT: Nevermind.. It wont work for 2.. found an great website with the info about the 5850 power requirements layed out better than AMD explained it.. That Corsair is perfect for 2 card since it has 4 6pin connectors(the +2 just means it can be an 8 connector), has enough amps and watts... :)
Just in case someone else needed this info, heres is the web site:
http://www.guru3d.com/article/rade [...] rossfire/9
Message edited by mrneil001 on 10-09-2009 at 09:32:44 PM
Reply to mrneil001
There are 1167 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
Related Content
