First Water cooling build help
My price range is about 600 including taxes
Water cooling kit including gpu block
New gpu
I'm in canada so preferably Canadian stores, Newegg.ca, ncix.com, canadacomputers, dazmode.com
1 answer Last reply
More about first water cooling build help
  1. what exactly are you planning to watercool?
    what case are you using?
    how do you want to mount your radiators?
    You should read the stickies in this forum, it will help answer some of your questions. As for watercooling, dazmode is good, but aquatuning.us, I find, is better.
Water Cooling Build GPUs Overclocking Product
