PC Case Problem
Forum CPU & Components : Power Supplies, PC Cases & Case Mods - PC Case Problem
Hello,
I have bought a antec p193 case and after installing everything i closed the front panel but i broke one of those plastic holders and the front panel is not mounting very good anymore on the case.
See http://dmdreams.be/DSC00285.jpg for more details
Is there a way i can fix this broken part ? Well the annoying thing is the case doesn't close very well anymore. I have build several computers and its the first time i had this problem.
Kind Regards,
Kris
Sponsored Links
if you still have the broken plastic park you can super glue it back to the front fascia panel - leave it to set full before attach the fascia to the case. I have had a few of these go on cases before so its not a loss just yet
Reply to ulysses35
thanks i will give it a try with super glue :)
Reply to Anonymous
Tom's Hardware > Forum > CPU & Components > Power Supplies, PC Cases & Case Mods > PC Case Problem
There are 1267 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
