Tom's Hardware > Forum > Graphic & Displays > Graphics Cards > Problem with my HIS 4850 ICEQ4 512?
Forum Graphic & Displays : Graphics Cards - Problem with my HIS 4850 ICEQ4 512?
Hi, I just built the system a few days ago
OCZ 500W PSU
e7400
HIS 4850
GSKILL Ram 2x2gb
Gigabyte EP43UD3L
After playing Age of Conan for an hour or two, I begin to notice that my FPS starts to get lower as time goes by. I usually average around 40-80 fps depending on the area. And 40 fps in towns. But after a period of playtime, I suddenly am stuck at around 20fps no matter where I go or what is on the screen. At this point, I restart the computer and everything is fine.
I am running CPUID hardware monitor and Fraps in the background.
For my temperatures, I am reading
32 C Idle and around 39 C load for the CPU
The graphics card idles at around 56C with ~25% fan speed, and during my gaming I usually notch it up to around 50-60%, so that with load it is still relatively cool at around 56C. I was just wondering if anyone had any idea what could be wrong? I'm gonna play a few other games for an extended period of time and see if the same type of result occurs.
Edit: I'm playing at 1440x900, and I have left the gpu and cpu at stock.
Thanks in advance.
Message edited by theburritobuddy on 07-31-2009 at 03:19:14 AM
Sponsored Links
If you're using a athlon dual core did you install the dual core optimizer patch?
Reply to gomi
i think hes using a 2 duo e7400!
Reply to fjc1998
There are 477 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
