Archived from groups: comp.sys.laptops (More info?)
I have a Targus Auto/Air Power Adapter PA350. I have used it well
with power tip #19 on my Panasonic Toughbook. I just bought a new
Fujitsu Lifebook S2020. Targus does not list a power tip for the
Fujitsu, however many, many other Fujitsu models also use power tip
#19.
Targus cust. support said they cannot say tip #19 will work for the
Fujitsu S2020, I think because they have not gotten around to testing
it.
I can tell you this:
- When comparing the laptop-side plugs on the Panasonic and Fujitsu AC
power supplies, the plugs look identical. And power tip #19 does fit
the Fujitsu.
Those of you who are knowledgeable about the Targus units and power,
etc., what do you think? Do you think it will work? Is this a good
idea to give it a try? What bad can happen?
You will be fine; nothing bad will happen. The 0.4 volt difference and
the difference in current capacity (0.1 amps) are both too small to
matter. If the plugs are physically the same, and the polarity is the
same, these are close enough to be considered identical.
> #19.
> it.
> the Fujitsu.
> - Specs on the AC power supplies are:
> Panasonic: Input 100-240 V~1.5-0.7A, Output 15.6V=3.85A
> Fujitsu: Input 100-240 V~1.2-0.6A, Output 16.0V=3.75A
> Polarity identical
> Thanks.
