Tom's Hardware > Forum > Graphic & Displays > Graphics Cards > Connecting an HDTV as a second monitor
Forum Graphic & Displays : Graphics Cards - Connecting an HDTV as a second monitor
I am building a computer for my parents and they want to use it to watch movies. I have never hooked up an HDTV to a computer and am wondering if I can hook it up as though it was a second monitor and have it as a clone to their regular LCD. Also, by doing this will I need a beefy video card (like an NVIDIA 280 series)?
Sponsored Links
No, you won't need a beefy graphics card. My HTPC is currently hooked up to my 32" HDTV (via and DVI --> HDMI cable) and to my projector (via a DVI --> VGA adapter and a lengthy VGA cable). The HTPC in question has an ATI Radeon HD2600Pro installed. I'd probably recommend an ATI Radeon HD4350 for your system. Low power requirements and should be enough to power both displays without issue.
-Wolf sends
------------------------------ System Specs:
Gigabyte EP43-UD3L Intel Core2Quad Q8400 8 Gig RAM
NVidia Geforce 8800GTS-640/Creative X-FI Extreme Music/Dual-Boot XP-64&Server2008
Reply to Wolfshadw
Dont't forget if you want to use "clone" mode both displays need to be set to the same resolution. I've used a hdtv (though only 720p) linked to my pc for some years and it's great, media centre with the (free) "my movies" software works very well (i have nearly 400 films and mymovies will download film info and allow you to select films by genre, rating etc). Link below:
http://www.mymovies.dk/
Reply to rtfm
Some of the newer video cards have HDMI outputs, if you're planning on using the TV's speakers. Just go to Newegg.com and search for HDMI video card. For example, the ATI 4870 from MSI has an HDMI output as well as the usual RGB 15-pin D connector. I suggest you stick with a digital output to the TV rather than analog RGB, assuming your HDTV has both types. Blu-Ray has HDCP copy protection but that shouldn't be a problem, although you may have to set the TV as your primary display in Windows Vista or 7, instead of cloning the image as you mentioned.
You should set the TV input to dot-for-dot (no scaling) and may have to adjust the overscan too, unless there's a PC setting, so that the image exactly fills the screen.
Reply to fazers_on_stun
There are 725 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
