Ok sorry, Im going to be running vista x64, windows 7 x64 when it comes out, I Use my computer for gaming, 3d modelling
Music, browsing the internet, but mostly for gaming,
SAS drives are the newer versions of SCSI. You won't ever use it. When you need a faster drive, you'll just get an SSD.
Here is an example. It's already outdated tech:
http://www.newegg.ca/Product/Produ [...] 6822145243
I figured since you were looking at a thermal electric CPU cooler you were wanting to get the most cooling you could. It also made sense given your MB choice. If you just want air, the best air cooler is this one:
http://www.newegg.ca/Product/Produ [...] 6835608007
The kit is good, but yes you can do better by building your own. I'm not the expert on this however, and you want to run your water cooling parts by the guys over in the overclocking forum to make sure you have the best setup. I don't think it's valuable to cool the RAM with water.
I have only seen the Swiftech pumps, some with mods, recommended for 12V systems. There are some AC pumps that are popular as well but I don't like those as they have to be controlled separately. I'm not familiar with the Thermaltake pump/res kit you linked.
