Tom's Hardware > Forum > Graphic & Displays > Nvidia > Persistent nv 14 (vid card power shortage) and crashes, help!
Forum Graphic & Displays : Nvidia - Persistent nv 14 (vid card power shortage) and crashes, help!
I just got a new custom built system, specs as follows:
Intel Core i7 920 (quad core @ 2.67 GHz)
Asus P6T Deluxe (Intel X58 Chipset)
3GB DDR3 1333MHz RAM
750W Corsair TX PSU
Western Digital RE3 WD1002FBYS 1TB 7200 RPM
Antec Nine Hundred Two Case
Into this I placed the EVGA NVidia 9800GT from my old system (which I replaced because of repeated hard drive failures, either because of a bad disc controller on the motherboard or possibly a bad power supply).
I am getting periodic BSOD's, each one accompanied by a massive list of NV 14 errors in the event log (that's insufficient power to the video card, as I understand it).
To my knowledge the power supply I have should be more than sufficient, is that correct? My BIOS is up to date, I've tried placing the card on different 6-pin cables, I'm not sure what else to try to solve this problem. Needless to say, I'm sick of mid-game crashes due to this issue. Any help in diagnosing and solving the problem would be greatly appreciated. Am I right to suspect that the card may have been damaged by my previous computer? Should I just replace it? Anything I should try first?
Thanks very much for any help.
Message edited by Vinraith42 on 08-02-2009 at 03:59:36 AM
Sponsored Links
Supplemental information: I'm now getting this error in the event log:
Source: System Error
Category: (102)
Event ID: 1003
No idea what that means.
Message edited by Vinraith42 on 08-02-2009 at 02:27:27 AM
Reply to Vinraith42
There are 1201 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
