Tom's Hardware > Forum > CPU & Components > CPUs > [Solved] 965BE. Air Cooler Help.
Forum CPU & Components : CPUs - [Solved] 965BE. Air Cooler Help.
Best answer from xaira.
Hey guys.
I'm about to buy Phenom ii x4 965 BE, and I need a good CPU cooling.
I do not want to go Water Cooling, so I would like to find like the best,
Air Cooling.
Please Help me out.
Thanks.
My Case will be CM 690, if that helps with dimensions.
Thanks.
http://www.newegg.com/Product/Prod [...] 6835207004
the spire is a little better, but newegg doesnt hav it
Sponsored Links
spire thermax 2, core contact freezer, no backplate, just clip in and enjoy
Message edited by xaira on 10-12-2009 at 05:19:39 AM
------------------------------ "Envy is ignorance" - Henry Thoreau : Best quote ever.
http://www.pingtest.net/result/3022953.png
Reply to xaira
Which would you recommend from Newegg. As i'll be buying my stuff from there, which would you recommend from them.
THanks.
Reply to jvwash
Best answer
Reply to xaira
The next stepping has already been listed on provantage, I really doubt that It will be long before it is released.
Reply to Attila_the_pun
I was thinking about...
ZALMAN CNPS9700
http://www.newegg.com/Product/Prod [...] 6835118019
From what some people say, it's a good cooler.
What do you guys think? is the
Better?
Thanks.
Reply to jvwash
The CNPS9700 is not considered a good cooler.... well at least that is what I have heard from more than 5 users here on Toms that actually have it.....
Go with the Core Contact just like xiara suggested....
or you can try this one :
ARCTIC COOLING Freezer 7 Pro Rev.2 92mm Fluid Dynamic CPU Cooler - Retail
http://www.newegg.com/Product/Prod [...] 6835186134
Message edited by OvrClkr on 10-12-2009 at 10:48:32 PM
------------------------------ 550 @ 4.0 Ghz 1.425v
BFG GTX 260 (216)
4GB G.Skill @ 940MHz
Thermaltake TP 850w
Reply to OvrClkr
the zalman is a good cooler.. its just more looks and not the best cooler.
when it first came out there was only a couple better but since then many that equal or beat its performance have come out.
That being said I wouldnt pay extra for it.
Message edited by rand_79 on 10-12-2009 at 11:17:21 PM
Reply to rand_79
No, you can connect the fans to the fan headers on the board. The 4 pin fan header is for the CPU cooler.
BFG GTX 260 (216)
Thermaltake TP 850w
Reply to OvrClkr
Well what i'm trying to get is..
that's a CPU cooler right? but it has a 3 pin connector for the Fan, so it won't work with my MOBO?
Reply to jvwash
Yes it will work, I thought you wanted to connect a regular case fan on the 4 pin header instead of the CPU fan.....
BFG GTX 260 (216)
Thermaltake TP 850w
Reply to OvrClkr
There are 950 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
