So I recently installed my HTPC and was starting to discover the fruits that Hulu has to offer. I went to watch an episode of the Simpsons, and when I went to full screen mode the video became all choppy with slow frame rates. Escaping the full screen mode the frame rate returned to normal (so it isn't my internet connection).
Basically my problem is that the computer I built is too weak to smoothly upconvert a Hulu video to 1920x1080. When the video is full screen the CPU is maxing out at 50% so that MAY be the issue. I'm not sure.
My vital equipment is this:
GIGABYTE GA-MA78GM-US2H AM2+/AM2 AMD 780G HDMI Micro ATX AMD Motherboard
AMD Athlon 64 X2 5050e
2x2 GB DDR2-800
Philips 1080p TV
Win 7 64-bit RC
Opera browser (would other browsers use both cores maybe?)
I am using onboard graphics to save power; I thought that the 780G chipset would be fine for non-gaming. What can I do to get better performance? Do I need to simply add a graphics card (4650ish) or do I need to get a better CPU? And if I need a new CPU, what would you suggest for low power on an AM2+ platform?
2x2 GB DDR2-800
Philips 1080p TV
Win 7 64-bit RC
