Tom's Hardware > Forum > CPU & Components > CPUs > Check cable signal
Check cable signal
Forum CPU & Components : CPUs - Check cable signal
my pc monitor is dead so i'm using
my lcd tv w/ vga slot, it's working like an ordinary montor, however there is a display error"check cable signal" that is appearing. pls help
Sponsored Links
I would check what resolution your LCD TV is capable of. I knew someone that tried using their TV when their monitor packed up - but the resolution was so low that windows would get to the Windows XP flash screen then nothing after that
Reply to ulysses35
- 0 +
what kind of tv is it? 720p is only 1366x768 usually.
Reply to rand_79
There are 1254 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
