Tom's Hardware > Forum > Homebuilt Systems > General Homebuilt > Hardrive making strange noise (shud i buy another one or wat?)
Forum Homebuilt Systems : General Homebuilt - Hardrive making strange noise (shud i buy another one or wat?)
Sup guys my hardrive have been making these sound when ever i turn on my pc !! when its turned on it clicks 2 time and continues to click after each 5-6 seconds (not a very loud click but click that can only be heard if the room is in silence)and sometime it freezez at the loading screen !!!
I havent solved the problem permanently but i found a way! i just simply press the reset button and hope it doesnt make the sound again! It works and everything work normally but i need to kno if its a hardware problem or just some power thing???
Windows xp
GIGABYTE S-Series motherboard 945PL-S3
Intel Core 2 Duo 2.20GHz 2MB L2 Cache 800 MHz FSB
2gb Ram DDR2 Running Dual channel
NVIDIA GeForce 7600 GS
Sponsored Links
What hard drive are you using and how old is it? Some hard drives are known to be noisy, Raptors for instance, while others are known to be near failure if a clicking starts. The major problem that I see is not the clicking itself, though that can be serious, but that it sometimes freezes during a load. This indicates the hard drive may be failing.
You do mention a possible power problem, but failed to identify the PSU and how old it is. Start up does put a high load on the PSU and if it is either old and breaking down or simply does not put out adequate power, that could also cause the problem you're experiencing as well.
------------------------------ Evil lurks in the databanks as it lurked in the streets of yesteryear. But it was never the streets that were evil.
Over 50. Seen it, done it, can't remember it, but I miss it.
Reply to Sailer
I'm using a seagate hardrive and its not that old i got it about 4 months ago !! i checked the power yestarday and its not the power giving trouble !!!
Reply to Stevenochango
There are 1219 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
