Yes No
Ads
Tom's Hardware > Forum > CPU & Components > Power Supplies, Cases & Mods > [Solved] HD 5770 & 5750 power requirements posted
Forum CPU & Components : Power Supplies, Cases & Mods [Solved] HD 5770 & 5750 power requirements posted
Best answer from jamesgoddard.
:bounce:
Here are the ATI recommended power supply requirements for the new ATI Radeon HD 5770 and 5750 video cards that just became available:
450 Watt or greater power supply with one 75W 6-pin PCI Express® power connector recommended
600 Watt and two 75 watt 6-pin connectors for ATI CrossFireX™ technology in dual mode
http://www.newegg.com/Product/Prod [...] 0%20series
Technical reviews:
http://www.tomshardware.com/review [...] ,2446.html
http://www.anandtech.com/video/showdoc.aspx?i=3658
Power consumption, temperature, and noise levels are very encouraging. :D
Reply to JohnnyLucky
I m not much impressed with these cards.
There is no point if upgrade for those who already have a 4870/4890/GTS 250/GTX 260.
Reply to shubham1401
Shubham1401 - The 5770 and 5750 were not meant to be an upgrade for any of the cards you mentioned. That was made clear in the technical reviews. The cards were meant for mid-level use much like the 4770 introduced earlier this year. Hardcore gamers who want high end cards will have to wait a little longer.
Best answer
PsychoSaysdie wrote :
5770 is a huge disappointment in my eyes. What a waste of money
Why??? This is a MID RANGE card that near enough matched the spec of last generations top dog - what's not to like...
It's direct competetor from Nvidia could be considered the GT250, and it's pissin all over that!
Reply to jamesgoddard
Will a Corsair CX400 handle 5770?
I know they recommend a 450w But CX400 is a very good PSU...
shubham - I have not seen the current (amps) requirement for the 12 volt rail(s) yet so I don't know.
yes - as long as your CPU is under 150W ish
I have an intel dg33fb mobo,c2d e4500@2.2 ghz,1ata hd,1sata hd,2gb ddr2 @667 mhz and want to buy 5750 or 5770.will corsair 400cx b enough for the specs
Reply to Omar_77
One question will the The modstream OCS 600W modular support 2 5770s ?
Message edited by Jaminkrazy on 02-03-2010 at 07:59:42 PM
Reply to Jaminkrazy
The OCZ ModXtream 600 watt power supply is an average psu. It probably would support a pc system with two 5770's but I would not guarantee it.
is an HEC 500w psu enough to handle a HD5750 with E5400 as the processor(intel)? planning to add units on my internet cafe
Reply to kevinxxx
There are 2072 identified and unidentified users. To see the list of identified users, Click here.
Ads
Latest best answer
TP-750 + Gigabyte GTX670 Windforce OC, how to wire up?
By rolli59, 3 hours ago:
1) Yes
2) Yes
I would use both none modular cables!
Best offers
Top experts
