This is my first build so I'm looking for some advice. I'll follow the suggested format for noob requests...
APPROXIMATE PURCHASE DATE: Aug-Sept 2009
BUDGET RANGE: ~$600CND but somewhat flexible (within reason)
SYSTEM USAGE FROM MOST TO LEAST IMPORTANT: internet, movies, music, photos, other apps, maybe some light gaming
PARTS NOT REQUIRED: need everything but I will get monitor/keyboard/mouse separately
PREFERRED WEBSITE(S) FOR PARTS: I will source from where ever is cheapest. I've placed links to newegg.ca below just to make things easier.
PARTS PREFERENCES: not married to anything but AMD seems to fit my budget. No Macs please.
OVERCLOCKING: Maybe. I'm leaning to a yes on this but will I need more CPU cooling?
SLI OR CROSSFIRE: I don't do any heavy gaming so I will probably stick to a fairly decent onboard video.
MONITOR RESOLUTION: 1080p preferred
ADDITIONAL COMMENTS: I'm basically looking for a simple, cheap build that is somewhat "future proof". I like to reserve the option to upgrade at a later date.
DVD: LIGHTSCIRBE SUPER MULTI 22X PATA - CDR-GH22LP20BLACK
(Mfg:LG Electronics, MfgPartNo:GH22LP20BLACK, SKU:10364808)
http://www.onhop.ca/Product/10364808?f=Shopbot I can get it for ~$30CND
GRAND TOTAL ~$565CND
Please give me some feedback/comments/suggestions.
Looks good, there dont seem to be any good combos on those parts for now but keep your eyes open as there are often some pretty sweet combos on AMD processors and motherboards.
If the 550 comes with the same heatsink as the 955 you shouldnt need more cooling unless you plan to do alot of overclocking.
Thanks for the feedback. It's nice to know that I'm on the right track. I'm not planning any crazy overclocking or unlocking the cores so I think I should be OK. Thanks again!
Thanks for the advice. I was actually looking at the Antec 300 originally but I liked the looks of the cooler master better (shallow...I know!). But taking a second look I think I will go with 300 (perfomance should outweigh esthetics...).
Your point on the PSU is well taken. I cut back basically to save some $$ but I think that I'll end up paying more if I have to replace the PSU when/if I decide to upgrade. I am hesitent on the OCZ you recommended because of the mixed reviews. What do you think of this one at the same price point:
OCZ> anything Rosewill. If memory serves, Rosewill is newegg's "namebrand". I learned the hard way, if there's anything you don't want to skimp on, its the PSU.
newegg reviews dont mean too much once you know the parts you are working with, most of the reviewers on newegg are morons unfortunately. DOA parts happen to even the best company but for PSUs OCZ, PC Power and Cooling, seasonic, antec, and corsair are some of the most reliable high quality brands out there. Rosewill parts are just like walmart specials, they buy it cheap from some OEM and slap their label on it, the quality varies from model to model.
I wouldn't trust the reviews.
Thanks for the info. I guess I didn't really put enough thought into the PSU. From the sounds of it I should maybe spend a bit more for a better 500W PSU. What do you think about this:
The one proximon suggest is a modular PSU and i would take that over the EA500 especially since your case selection has a top mounted PSU. The EA500 has 8 cables coming out of it and you only need 3 of them so thats alot of extra wires to deal with. Im quite happy with my EA500 but with the amount of cables i have sitting at the bottom of my case it would be hell with a top mounted PSU.
I do think the Delta-built EA500 is the better PSU. It's well tested whereas most of the OCZ line gets fewer reviews... just because there are so many I expect. PSU reviews are not like video card benchmarks though Sometimes it's hard to say.
Either the earthwatts or the OCZ really. The 450 Corsair would work for you as well. What kind of upgrades are you worried about? If you're that worried, step up and get the Corsair 650.
A bit more expensive, but you're covered both power wise and still within budget. About $30 more, but has free shipping. Personally I prefer the single rail, but that's just me.
Good points to consider. So, I think the most likely upgrades in the near future would be a video card and/or a quad core CPU. With this in mind, the 450W PSU may be on the low side. The 650W is a bit more that I wanted to spend and maybe a bit more than I need.
However, there is a happy medium with this 550W PSU for ~$75:
I'd think the 550 will be fine for you, especially if you're using on board video. I'd go with this one from newegg. Price is about the same, but has a $30MIR.
So I finally built my first computer!! I fired it up last night and it actually worked (I was quite excited/relieved). When I turned on the main toggle I paniced when the CPU fan didn't fire up...then I realized I never pushed the power button (I felt like a big time newbee at that moment!!). Anyway, everything seems to be working fine but I wanted to send out a huge thank-you to Proximon, AMDThunder and hunter315 for all your help. You guys are the best!!
Here's my final build:
Motherboard: ASUS M4A78T-E AM3 AMD 790GX HDMI ATX AMD Motherboard
