Tom's Hardware > Forum > Homebuilt Systems > New System Build > Fans still necessary with liquid cooling?
Forum Homebuilt Systems : New System Build - Fans still necessary with liquid cooling?
Are cooling fans still necessary if i install liquid cooling system?
Sponsored Links
Other things in your computer make heat besides the things you liquid cool, which is usually just the CPU. You need less fans, but you can't get rid of them all together.
------------------------------ Sager NP5793 | T8100 2.1GHz | 4GB DDR2-667 | 8800mGTX 512MB | 320GB 5400rpm | 1920x1200 17", 24" | Win 7 x64
Reply to frozenlead
+1 Well put. The RAM, northbridge, voltage regulators, hard drives, etc... all should have some air flow.
The radiator will also need fans to help it dissipate heat.
Reply to shortstuff_mt
^ Unless the rad is passive. You could go the same route with the case, but then you run into heat problems. Non-passive radiators still require fans.
Reply to not moose
There are 528 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
